Page 1196 of 1378 <123 ... 119511961197 ... 137613771378>
Landymatt
First camping trip of the season. Just a hose pipe in a field.
But a fire pit, melted chocolate and strawberries to dip keeps everyone happy.
Post #774984 26th May 2019 5:38am
Co1
^^^ I assume the kitchen sink is in there somewhere? ๐Ÿ˜‚
Post #774990 26th May 2019 6:39am
Sulisuli
Sulisuli wrote:
Zed I measured and remeasured before offering the plate up because the self adhesive strip to mount it with are nearly impossible to remove, so itโ€™s staying where it is, perhaps the new photo I have posted in the original posting looks better?
As I wonโ€™t be moving it, do you want to pop the fiver in a charity pot Rolling with laughter
The dust caps are really good Iโ€™m impressed Iโ€™m going to get 4 spares to put on the horse trailer next Thumbs Up
Zed your a top fella and a man of your word Bow down 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #775005 26th May 2019 8:08am
excossack
Removed front prop and checked UJs and while off I greased the nipples - Part of the hunt to try and solve the wheel wobble issue (55-60mph) - some roads worse than others
Rear wheels balanced up OK as are the fronts and the tyres are OK. No play in ball joints according to the garage who had a look.
Started making the mounting plate for the Eberspacher from some stainless I had hanging around.
Modified the rear corner protectors I got and now these are in for blasting and powder coating.
Took the rear chequer plates covers off also for blasting and coating. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #775399 29th May 2019 8:37am
Hi John, have you checked the front panhard rod bushes, and or checked the bolts for tightness?
Post #775400 29th May 2019 8:50am
excossack
Hi Greeni.
Replaced the bushes with gen LR ones along with new bolts/nut and same for the radius arms (all bushes and buts/bolts) - maybe a retorquing/checking would be an idea. 1999 Defender TD5 110
Regards
John M0VAZ
Post #775402 29th May 2019 9:08am
My v8 became vague this past couple of weeks, was the panhard rod bolt slightly loose.
Worth a try Thumbs Up
Post #775403 29th May 2019 9:14am
excossack
certainly worth a poking with a Mr T. Orque wrench. 1999 Defender TD5 110
Regards
John M0VAZ
Post #775408 29th May 2019 9:28am
Have a look at the steering box drop arm area that there is no play and the steering column UJ too.
Also although may not seem associated damper bushes too, they can cause all sort of feedback issues whilst driving. $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #775423 29th May 2019 12:16pm
excossack
Whats the best way of checking UJs? just wiggle steering wheel left/right
I did think about the shocks - will also have a look at them & bushes 1999 Defender TD5 110
Regards
John M0VAZ
Post #775429 29th May 2019 2:22pm
Stacey007
Sorted my front lower a/c grill with stainless grill & fixingsand fitted some modern style indicators๐Ÿ‘
Indicators are dark smoked led Knight rider style... I think they are great ๐Ÿ˜€
Post #775467 29th May 2019 8:12pm
Zed
Post #775469 29th May 2019 8:16pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Rolling with laughter Rolling with laughter Rolling with laughter a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #775470 29th May 2019 8:26pm
Stacey007
Love it ๐Ÿ‘๐Ÿ˜€๐Ÿ‘๐Ÿ˜€๐Ÿ‘๐Ÿ˜€๐Ÿ‘
Post #775487 29th May 2019 9:22pm
mk1collector
Drove to the Cheshire Landrover experience for a drive around their grounds. Unfortunately the defender we booked to use had broken so we ended up using a disco 5 which is very capable but Iโ€™ll stick to the defender Wink Wink Ray
My build thread
Post #775605 30th May 2019 6:36pm
