![]() | Home > My Defender > An Anorak's Utility Station Wagon |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10891 ![]() ![]() |
Will be waiting patiently for the " small " mod to be posted
sgreenham Member Since: 27 Apr 2019 Location: Southampton Posts: 145 ![]() ![]() ![]() |
Just found the sold steering wheel thread on the forum so ignore the post above... Apart from the "loving your build", I do still love the build.
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
I've spent the last couple of weeks, on and off, fashioning a mounting bracket for a fire extinguisher from various bits of aluminium channel and angle, to fit in the dead space to the right of the rear door. I'm mildly annoyed with Land Rover for being such cheap skates with their trim for the rear of USW's, and have been working my way around filling in or making use of the gaps.
The brackets consist of two lengths of 2 1/2" x 1 1/2" ali channel, cut to shape, two 30mm wide 1 1/2" angles and a length of 30mm wide flat bar, which have all been etch primed and sprayed satin black. There's also a 24mm wide by 12mm thick nylon spacer and a selection of nuts, bolts and screws: ![]() Click image to enlarge The channel sections are mounted top and bottom of the end panel to the driver side of the rear door. The top bracket picks up on the two bolts that secure the roof to side clamp and it's here that the nylon spacer is required, due to the irregular shape of the top of the panel. The existing bolts were removed and replaced with two slightly longer M8 stainless ones. The bottom bracket is secured to the bottom edge of the panel with three self-tapping screws. The two angle pieces are bolted to the channel sections and the flat bar spans between the two to provide a flat surface for the fire extinguisher bracket to fix to: ![]() Click image to enlarge The paper behind the bracket was a temporary measure to allow me to mark out the position of the window aperture in the trim and mark a vertical line to work to. I sandwiched some dense foam between the bottom channel and the body, and between the top channel and the angle piece, to give a small degree of shock absorption to the whole thing, as the extinguisher is a heavy lump. In this picture, the extinguisher bracket has been bolted to the flat aluminium bar: ![]() Click image to enlarge And finally, with the extinguisher in its' mount and the trim back in place: ![]() Click image to enlarge At some point, I will trim the area behind the mount with some grey vinyl cloth to match the switch panel mount on the other side, but that's a job for another day. The various measuring, cutting and drilling required for the bracket has already taken an inordinate amount of time, enough to give a very good appreciation of Project Binky! Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
I also spent a few minutes today replacing the flaky 'Diesel Fuel' sticker with this etched nickel silver version:
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5241 ![]() ![]() |
Where do you dispose of out of date fire extinguishers? I have two that came with the D. Also I think project binky is just bracket heaven! Everything they do needs a bracket of a gusset, or even a filet. I am currently watching the camper transporter thing they are starting on, which is on the side. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3350 ![]() ![]() ![]() |
Procta, Our local recycling centre takes fire extinguishers.
Nice work Anorak. Very tidy indeed. |
As always LRA, nice detailed work gone on there and i would agree with you with the Project Binky comment, that is an awesome project in it's self
Thank you, chaps. It keeps me off the streets. Darren
Peregrine_White Member Since: 05 Feb 2019 Location: North West Posts: 68 ![]() ![]() ![]() |
If you don't mind me asking where did you get the diesel sticker from it looks much better quality than lots I have seen online?
Good old eBay. It's not a sticker, as such. It's nickel silver and is secured with the two pop rivets shown. Darren
Despite some misgivings, today I fitted a battery to fuse box relocation kit, as supplied by LRD Security. Some time ago, I expressed some scepticism about the value of this kit but eventually I succumbed on the basis that the amount of time I have to spend on this stuff is often limited and it offered a quick solution, albeit at a price.
![]() Click image to enlarge The principal of the kit is straightforward - it's a length of cable that feeds the fuse box under the drivers seat from the battery under the passenger seat, passing along the top of the seat box. It replaces an existing cable that runs underneath the vehicle, which is exposed and therefore vulnerable to attack by thieves. Whilst the kit is now installed and working as intended, with hindsight I wish I'd made something up myself. The reasons are threefold: firstly, the instructions were poor and not correct for XS spec. Puma's (nor probably TD5's); secondly, some of the parts don't fit and finally, the kit is very basic and could be improved on with a bit more thought. Beginning with the instructions, they describe gaining entry to the two underseat boxes via an existing hole fitted with a bung in the rear outboard corner of each. The main problem here is that on vehicles with heated seats, that hole is already in use for the wires that feed the heating pads. This brings me to the second problem: the kit includes two open grommets for those holes but they're the wrong size, for a Puma at least. I got around this problem by removing the existing grommets, which left enough space to pass the new conduit-clad cable through the same holes. I then tightly cable-tied the heated seat wiring to the new conduits to prevent them moving and chaffing. The final issue is one of aesthetics. The new cable runs across the back of the seat box and is secured to existing fixings with large P clips, like so: ![]() Click image to enlarge ![]() Click image to enlarge The problem with this is that, to me at least, it all looks a bit Heath Robinson. In due course, I'll try and tidy this up with some rigid conduit, perhaps mini-trunking. Apart from all of the above, in my case the cable was only just long enough, although that's no fault of the kit. Because I have a twin battery set up, the main battery is further forward than the standard position. Finally, the most tricky part of the installation is gaining access to the connection onto the fuse box, as the plastic shroud is a sod to remove. Access is made easier by undoing the three bolts that hold down the fuse box, which screw into captive nuts, as follows: ![]() Click image to enlarge Anyway, after a degree of cursing and head scratching, another layer of security is now in place. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
I fitted the same and wasn't terribly impressed but it is a security improvement. I'm hoping a better solution becomes available.
Roger Member Since: 26 Apr 2018 Location: Hampshire Posts: 71 ![]() ![]() ![]() |
Anorak, to hide the unsightly cable I routed it round the front of the seats and through an otherwise unused metal conduit that lives between the centre removable seat box panel and the gear stick cowling. Might not be suitable for you as I drilled holes in the front of the seat boxes and sacked off the plastic conduit but was able to hide everything under the carpet - vinyl might not be as forgiving!
