Home > My Defender > My 1984 Ninety |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 719 |
Steady progress tonight;
Unseized and stripped the low range mechanism, cleaned it all up, new o-rings lots of fresh grease ready for bolting back on. Appears to be original as uncovered an '84 in the casting. Click image to enlarge Started the loose fit of the freshly/badly painted new battery box panels. Bit of a sod getting it all together due to seatbox still being in, but it's there now ready for drilling and riveting Click image to enlarge Instagram: L90andy My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
30th Apr 2019 8:59pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5208 |
i think my dads needs to do this on his, the low ratio leaver I seized to hell. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
1st May 2019 5:05am |
Byamin Member Since: 28 Apr 2019 Location: South Island Posts: 8 |
Nice job on the battery box repair, looks very tidy! Lucy saved from A parts shelf, 1984 110 V8
Instagram: @ben_j_soffe |
1st May 2019 6:13am |
Battery box all fixed and seam sealed. Before and after
7th May 2019 12:01pm |
What a great job. Well done for persevering with doing it in-situ. Darren
7th May 2019 3:17pm |
Thanks! Yeah its pretty satisfying to not know how the job is going to work out but diving in and getting a good result anyway. Definitely helps I can take my time as its not a daily driver.
Got the refurbished hi/lo mech back on too. The keen eyed amongst you will see I reversed the direction of the linkage pin which was deliberate, thinking "who cares if its a b*tch to get the split pin out I won't have to worry about that for years!" then realising that I forgot to put the nylon bushes back in the linkage And yes, it was a b*tch, but its all done and back in properly now. Another one ticked off Click image to enlarge Next installment - diff lock shenanigans. Instagram: L90andy My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
8th May 2019 2:48pm |
good repair on the battery box, we have to do something with my dads transfer box linkage as its seized to hell. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
8th May 2019 4:20pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
Good jobs done there 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
9th May 2019 8:11pm |
Thanks
Onto the INOP diff lock then. Tunnel already being out meant I had decent access to the mechanism, however it was totally obscured with muck. Click image to enlarge Searching the web didn't come up with any info on how or what to take apart, so perk of the job - checked the CAD Looked pretty simple, so got stuck in. Drivers floor panel had to come up a bit to get tool access but got there in the end. Shame reality isn't as clean as virtual! Click image to enlarge Click image to enlarge The good news was the mechanism wasn't seized, so it was just cleaned up. The issue appears to be that the movement isn't transferred from the knob to the mech as the amount of slack at each pivot means the mech doesn't fully actuate. I replaced the nylon bushes and managed to pack the joints with extra washers to remove the slack. Disappointingly on re-assembly it still doesn't fully work. The main culprit is the centre pivot. Latest thinking is to drill out the hole and fit a larger roll pin, and make some more spacers. Only the earliest 13D spec LT77's had this cast arm, later versions changed to the bent metal arm. Perhaps cost and reliability were drivers for that. That makes them rare, and a new one would be £245 Click image to enlarge So it's all back in for now and that's where I'm upto tonight Instagram: L90andy My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
15th May 2019 10:38pm |
Good that you got stuck in and found out the problem and hopefully get it fixed and working right when time allows 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
16th May 2019 8:16pm |
where did you get the stuff to sort the linkages out? my dad really needs his sorting out, if you can supply the links I can get the bits and my dad can sort his out. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
18th May 2019 9:42pm |
Hi Procta,
It's a busy area of the car with separate linkages for hi/lo and diff lock. Both had issues on mine. Start with removing the centre access cover under the middle seat (or cubby box) and the tunnel where the levers are (they can stay attached). Then you'll be able to see all the linkages properly. My hi/lo was seized at the transfer box end so removed the 6 bolt housing as mentioned previously. The shaft was stuck in the housing so loosened it off and replaced the o-rings (part no.FRC5575). I needed 2, but think later boxes only used 1. Fresh grease and all back together, no new linkage bits required Different story for the diff lock though, still ongoing with that Hope that helps. Instagram: L90andy My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
19th May 2019 8:47am |
What I thought was going to be a relatively simple resurrection of the diff lock was misguided. Anyone got a towel so I can throw it in!?
I've now replaced all bushes, packed out the pivot slack with additional washers and tonight replaced the diff lock switch. No change Going to have to get inventive now and get some bits machined to remake the pivot bracket. Or convert to a later type of mech but I don't have the pivot boss on the side of the gearbox so more head scratching required. Click image to enlarge In an effort to at least make positive progress here is a little thing I've 3D printed to hold the interior light now I've converted to soft top. It sandwiches between the mirror mount and holds the light at the same angle as the sunvisors. Click image to enlarge Here it is in place to test the positioning; Click image to enlarge And here it is with the light fitted. I'll whip it off the next time I've got the paint out and get some satin black on it Click image to enlarge I'll put the interior all back together for now as there is nothing else I can do on the diff lock for a while and it only takes a few minutes to get the access panel and tunnel out again. Instagram: L90andy My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
20th May 2019 8:36pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1835 |
Liking the light mount 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
20th May 2019 8:46pm |
