Home > My Defender > An Anorak's Utility Station Wagon
Page 14 of 57 <123 ... 131415 ... 555657>
Alloy Grill Badge
I braved the suddenly very wintery weather today to fit a nice little alloy Land Rover badge to the front grill. The badge came from eBay and was pre-drilled with a couple of holes to take M3 bolts.
To mount it to the grill, I made a little ali plate, drilled and shaped to match, to clamp it in place:
I covered the back of the badge and front of the plate with foam tape, so they won't damage the grill finish:
Clamped in position with M3 allen screws and nylocs:
I'm really pleased with the result. I also took the opportunity to replace the bolts securing the grill with some blackened versions, whilst I had it apart:
 Darren
Post #749393 5th Jan 2019 5:08pm
Gearstick Collars
A bit of frippery that makes me smile:
 Darren
Post #749395 5th Jan 2019 5:17pm
LED High Level Brake Light
Another little task today was to fit an LED high level brake light. This is the Bolt on Bits version, which seemed like an absolute bargain at £30:
The moulding appears identical to the original, except without the hole for the bulb holder:
It fits in exactly the same way and the wiring is 'plug and play':
From the outside (yes, I know it's dirty Laughing ):
And in operation:
It's certainly bright enough and lights up noticeably quicker than the regular bulbs in the main lights. A relatively inexpensive and satisfying upgrade Very Happy Darren
Post #749397 5th Jan 2019 5:18pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Looks good Thumbs Up never can give others enough warning as the normal lights are not the best. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #749409 5th Jan 2019 5:59pm
L110CDL
Nice little jobs done there Very Happy Clayton.
Keeper.
Post #750249 9th Jan 2019 10:19pm
Thanks, chaps.
There's a long list of things still to do but most of them will have to wait for warmer weather Rolling Eyes Darren
Post #750316 10th Jan 2019 2:59pm
Good old Opie - that's another years' supply Smile
 Darren
Post #753500 23rd Jan 2019 10:59pm
PCM
Just read your thread about 5 times. Riveting read. Great job on everything. I've just soundproofed mine and can relate to everything you said. Next step is the second battery. Your notes will be essential and save me a ton of time.
Cheers and keep it up.
p.s. If you ever want to sell it, let me know Smile
Post #754685 29th Jan 2019 4:07am
Thanks Cool
Not for sale in the foreseeable future Laughing Darren
Post #754709 29th Jan 2019 9:40am
PCM
I don’t blame you. Wink
Post #754772 29th Jan 2019 2:43pm
Just replaced all three wiper blades after damaging two in the cold weather a week or so ago Rolling Eyes
Also added this handy strap to my on-board kit:
 Darren
Post #758282 12th Feb 2019 11:05pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Great thread, I have been looking at the high level LED brake light. There seems to be some very expensive options available but I think I will be going with the same option as you. Looks like it does the job just fine. Thumbs Up
Post #758285 12th Feb 2019 11:16pm
Yeah, I'm really pleased with it. Darren
Post #758286 12th Feb 2019 11:22pm
sweepc
[quote="sweepc"]Great thread, I have been looking at the high level LED brake light. There seems to be some very expensive options available but I think I will be going with the same option as you. Looks like it does the job just fine. Thumbs Up[/quote]
My light arrived yesterday, can't wait to get the car back on the road and get this fitted. Thumbs Up
Post #758943 16th Feb 2019 9:35am
Brake Pads - Rear
I was bloody annoyed this week, when my 110 failed it's MOT! Only for worn rear brake pads, which I kind of knew about as they were noted at its' last service, but thought there was enough to last until next Rolling Eyes Ho hum, I guess that's what the test is for. Anyway, as a result, I've had to get my hands dirty and replace the pads.
The pads that I've used are Borg and Beck, purely because they were available from my local motor factors. Interestingly, they're chamfered on one edge, so are effectively handed and have to be fitted the right way around:
Before starting on the calliper, I removed the cap from the master cylinder and wadding a towel around it in case any fluid was pushed out. It turned out that this wasn't necessary as the level didn't get to the top, but it's a useful precaution.
With one side jacked up and the wheel removed, the guide pins came out easily. To then free the pads, I used a couple of small G clamps to press them back against the cylinders, to allow enough clearance:
In hindsight and with more time, I'd have replaced the pins and springs, but the originals cleaned up pretty well and were treated to a smear of copperslip before re-assembly:
The cylinders needed to pushed back in a little further to allow the new pads to be fitted, which again was done with a small G clamp. I also gave everything a blast of brake cleaner beforehand to preserve the seals. Then, with more copperslip on the backs of the new pads, everything was put back together:
The old pads, marked Ferrodo, really were quite worn:
A quick test drive and all was well, so it'll be back for the re-test on Monday. Darren
Post #761660 3rd Mar 2019 11:15am
