Home > Maintenance & Modifications > Td5 oil filter removal tips, nightmare |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Any hints on getting the oil filter loose on the td5 mine is welded in place just won't shift. I've tried some adjustable oil filter pliers but still impossible to grip and turn it. Tried a chain and strap wrench but not enough room to work and seemingly impossible. Next option is the socket style like below but open to suggestions
eBay Item No. 382277743103 Last edited by Djcla on 4th Nov 2018 5:28pm. Edited 1 time in total |
4th Nov 2018 5:18pm |
Tried a screwdriver but it just seems to rip like a tin can didn't push it through both sides mind.. talk me through the rope thing. Turning it towards the front of car which i hope is right as it's upside down lol
4th Nov 2018 5:29pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2166 |
Drill a hole and put a screw driver thru it. My last one took me 3 hours to remove.
Sounds excessive but its not too hard to remove the turbo for better grip and access Instagram @defender_ventures Empire Tuning - Agent |
4th Nov 2018 5:44pm |
Through both sides you mean? I found the casing just seemed to rip but I didn't go lol way through
4th Nov 2018 5:49pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
I use these for them, and other tight filters. I would only really use them if junking the filter.
https://www.screwfix.com/p/teng-tools-oil-...lsrc=aw.ds |
4th Nov 2018 6:09pm |
Ah they were my next purchase I mean I've already spent a load trying to get it off so what's an extra £20 lol.
4th Nov 2018 6:40pm |
8619simon Member Since: 04 Nov 2016 Location: North Wales Posts: 247 |
Had the same issue last week! Bought one of these:
https://www.amazon.co.uk/Professional-Piec...=3+leg+oil Works a treat with the added advantage its great for limited space. A long extension on the drive and its off in a few seconds from underneath |
4th Nov 2018 6:56pm |
Ok and there is enough room to get it on underneath i take it?
4th Nov 2018 7:20pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8026 |
I use the three legged one, on td5 I tend to take the turbo oil drain off to improve access and avoid damaging it. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
4th Nov 2018 7:55pm |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
I use the Strap to tighten it, and a flat long screwdriver and a hammer to remove it, I hammer it on the top lip, normally it breaks, but it is going out anyway Augusto
Defender 110 TD5 2001 Discovery 4 TDV6 |
4th Nov 2018 10:09pm |
Dieseljock Member Since: 03 Jun 2017 Location: Inverclyde Posts: 31 |
This is what i use for mine. Works a treat. I use it day in day out on JCB transmission filters which are always very tight. Facom FCMU48PB Oil Filter Wrench https://www.amazon.co.uk/dp/B0051HEWB0/ref...3BbTJEZ6NT
4th Nov 2018 11:01pm |
Finally got the git off using the filter pliers that arrived last night from Amazon which ain't to bad for the price. Oil everywhere but job done now to attach the new one.
https://www.amazon.co.uk/Goodyear-Adjustab...ref=plSrch |
5th Nov 2018 11:08am |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
I've definitely done that before |
5th Nov 2018 11:14am |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Haven't we all
5th Nov 2018 2:05pm |
