Home > Maintenance & Modifications > Td5 oil filter removal tips, nightmare
Djcla
Any hints on getting the oil filter loose on the td5 mine is welded in place just won't shift. I've tried some adjustable oil filter pliers but still impossible to grip and turn it. Tried a chain and strap wrench but not enough room to work and seemingly impossible. Next option is the socket style like below but open to suggestions
eBay Item No. 382277743103
Post #738608 4th Nov 2018 5:18pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Hi
tied rope round mine and used screwdriver to tighten rope then undo filter. Word of caution, don't turn it the wrong way and tighten it Shocked
If all else fails a long screwdriver through the middle and unscrew that way.
Good luck.
Post #738609 4th Nov 2018 5:27pm
Djcla
Tried a screwdriver but it just seems to rip like a tin can didn't push it through both sides mind.. talk me through the rope thing. Turning it towards the front of car which i hope is right as it's upside down lol
Post #738610 4th Nov 2018 5:29pm
bankz5152
Drill a hole and put a screw driver thru it. My last one took me 3 hours to remove.
Sounds excessive but its not too hard to remove the turbo for better grip and access Instagram @defender_ventures
Empire Tuning - Agent
Post #738613 4th Nov 2018 5:44pm
Djcla
Through both sides you mean? I found the casing just seemed to rip but I didn't go lol way through
Post #738616 4th Nov 2018 5:49pm
NickMc
I use these for them, and other tight filters. I would only really use them if junking the filter.
https://www.screwfix.com/p/teng-tools-oil-...lsrc=aw.ds
Post #738622 4th Nov 2018 6:09pm
Djcla
Ah they were my next purchase I mean I've already spent a load trying to get it off so what's an extra £20 lol.
Post #738633 4th Nov 2018 6:40pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Had the same issue last week! Bought one of these:
https://www.amazon.co.uk/Professional-Piec...=3+leg+oil
Works a treat with the added advantage its great for limited space. A long extension on the drive and its off in a few seconds from underneath Very Happy
Post #738641 4th Nov 2018 6:56pm
Djcla
Ok and there is enough room to get it on underneath i take it?
Post #738650 4th Nov 2018 7:20pm
jst
I use the three legged one, on td5 I tend to take the turbo oil drain off to improve access and avoid damaging it. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #738656 4th Nov 2018 7:55pm
ajps72
2001 Defender 110 Td5 SW Chawton White
I use the Strap to tighten it, and a flat long screwdriver and a hammer to remove it, I hammer it on the top lip, normally it breaks, but it is going out anyway Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #738680 4th Nov 2018 10:09pm
Dieseljock
Scotland 2003 Defender 90 Td5 HT Zambezi Silver
This is what i use for mine. Works a treat. I use it day in day out on JCB transmission filters which are always very tight. Facom FCMU48PB Oil Filter Wrench https://www.amazon.co.uk/dp/B0051HEWB0/ref...3BbTJEZ6NT
Post #738694 4th Nov 2018 11:01pm
Djcla
Finally got the git off using the filter pliers that arrived last night from Amazon which ain't to bad for the price. Oil everywhere but job done now to attach the new one.
https://www.amazon.co.uk/Goodyear-Adjustab...ref=plSrch
Post #738730 5th Nov 2018 11:08am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I've definitely done that before Embarassed
Post #738732 5th Nov 2018 11:14am
Tommo
Haven't we all Rolling with laughter
Post #738761 5th Nov 2018 2:05pm
