Home > Maintenance & Modifications > Td5 oil filter removal tips, nightmare
Page 2 of 2 <12
miker
Djcla wrote:
Finally got the git off using the filter pliers that arrived last night from Amazon which ain't to bad for the price. Oil everywhere but job done now to attach the new one.
Remember, make sure the old seal came off, smear of oil on the new seal and hand tight is tight enough! I've never had a leak and have always been able to remove by hand the next time.
Have you done the rotor filter too?
Post #738792 5th Nov 2018 4:14pm
AJC
I use my right hand, never had an issue.
Post #738793 5th Nov 2018 4:20pm
gilarion
I use one of these and I have never had a problem with either removal or tightening the new one.
https://www.eurocarparts.com/ecp/p/tools/c...amp;t5_444
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #738795 5th Nov 2018 4:25pm
Djcla
Is that the filter inside some metal housing with the 2 bolts holding it in place in which case yes and I did the fuel filter. I'll check for the rubber seal thanks for the tip I've not progressed further as I'm waiting for a new drain plug to arrive that isn't rounded off. Thankfully I bought some very handy Irwin bolt extractors a while back.
Post #738799 5th Nov 2018 4:34pm
miker
Works great assuming the last person to maintain it wasn't the Hulk!
With an oil filter on that tight, and a rounded drain plug, Sounds like Djcla's motor was tended to by Thor at it's last service!
Post #738801 5th Nov 2018 4:41pm
AJC
I fir it prior, only ever hand tighten them, did a service on my brother in laws for him and had to get the grips out for that one.
Post #738806 5th Nov 2018 4:55pm
Djcla
I don't trust garages at best of times but it's sure had some abuse when servicing it. The drain plug was in crazy right probably via an impact wrench so figured best get a new one than reusing it. Axle, gear box and transfer oils next as I wonder when or if they were last done.
Post #738807 5th Nov 2018 4:55pm
MadTom
I was also fighting the filter for long time, also tryied different universal wrenches borrowed from friend. But there is simple working solution: https://www.ebay.co.uk/itm/Land-Rover-TD5-...:rk:8:pf:0 - spanner like this. Easy to use, fast and simple. From fight to loose and tighten, to just few seconds of easy work.
There are two different shapes of the filter end and two different spanners. I have bought both types, just to be sure, when removing the old filter. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #738812 5th Nov 2018 5:27pm
Djcla
I bought one of those to start with but the teeth were a fraction too long and the eBay guy I bought it off said it would only fit genuine filters. I tried filing the teeth down but it just wouldn't grip enough
Post #738816 5th Nov 2018 5:53pm
MadTom
As I wrote, there are two types of these wrenches. I have bought both, used both, and it works perfect. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #739015 6th Nov 2018 3:18pm
Djcla
Wish I'd known there was two types lol anyway least with the pliers I can remove non landy filters as well
Post #739030 6th Nov 2018 5:13pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Hi Djcla
glad its progressed. I would also check the axle oil and also the transfer box oil and gearbox oil as once there done you know its sorted. What about air filter?
As for changing oils in the gearbox etc always make sure you can loosen the filler plugs prior to draining Thumbs Up
If you do these buy a 5 litre garden sprayer and put oils in that, pump it up and watch it flow Very Happy
Good luck
Tommo
Post #739035 6th Nov 2018 5:40pm
Djcla
Cheers bud, air filter is done and the other oils are next on my list but this isn't a cheap task so I'll probably do as and when I can afford it. I also need to figure out what oils to buy.
Post #739038 6th Nov 2018 5:45pm
Page 2 of 2 <12
