![]() | Home > Maintenance & Modifications > Corrosion Prevention Guide! |
edo Member Since: 20 Aug 2018 Location: Devon Posts: 379 ![]() ![]() |
I only see a digger Chris, is mine under the mud pile?!!!
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
It's coming Ed, hang on
![]() Here you go... ![]() Click image to enlarge |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
lovely worrk on the foundations there ! looks like it was a lovely dig too, no rock or stones.
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
Very tidy excavation, very tidy site
![]() ![]() 2008 SVX 90 2000 XS TD5 90 |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3571 ![]() ![]() ![]() |
Only if you had the method statements and risk assessments
![]() No Sulisuli, you are right all very neat and tidy. I would not of expected any less from Zagato. It looks great ![]() |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1876 ![]() ![]() |
Horace the Corris 2016 XS HT due with Chris tomorrow for the usual . . . . . . . . . . Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
Thanks folks, lost two stone doing the work ![]() ![]() ![]() Sorry CarMan I forgot to take a picture of your 90 and the preceding 110 which was of a similar age and also in very nice condition. They are still out there, get em treated folks against the next onslaught of salted roads ![]() |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 ![]() ![]() ![]() |
Apologies if this has been asked before but what is the shelf life of Dinitrol in the real world? 18 months as stated if kept in a temperature controlled area?m
Tricky to say. If it is in the large drums with the heat bands around the drums as we need here in the UK due to the cooler climate then I would say 18 months is probably about right with a compressor. It is epoxy based (a glue) so can go off quickly in the wrong conditions/useage method!
For Aersols it is noticeable the newer they are the better it flows and comes out of the can. I keep my stock fresh and usually just order what is needed (The new Dinitrol owner which cocked up supply has sold the company apparently and supply is no longer a problem. LT is going cheap if you need any from Rejel ![]() Don,t risk buying cheaper old stock you sometimes see on EBay! Stock can be 3-4 months old already here in the UK as it comes from Germany and waits in storage. |
Zagato, thank you for your great explanation (and contribution to the entire topic by the way)! Normally I am using the 1ltr cans and get a full box. Just wanted to ensure I am ok with the 18 months. m
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2957 ![]() ![]() |
Does Zagato have a website?
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
http://ccautomotive.co.uk/ Currently under construction... James
Yes it has been under construction for a couple of years. Martin has offered to do it and we really must get it sorted my work comes in mainly through recommendations so I have not needed a site BUT I would very much like to have a good one. I have done my own in the past through Mr Site but a more impressive site is needed these days. Unfortunately many people are taken in by full page spreads in magazines and showy websites, some even with images or text "borrowed" from me... I wouldn,t mind IF they actually did the work described
![]() ![]() ![]() I recently had in a near new Defender in white which was perfect for clear pictures so I am all ready to get a site up... E.g. This pic can be used for bulkhead leaks and surface rust which I treat... ![]() Click image to enlarge |
