Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 |
All back together and working a treat. Smoother and quieter for sure. Now to get some miles done before Friday 2002 90 Td5 Station Wagon
2nd Sep 2018 6:22pm |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
Great news George
2nd Sep 2018 7:12pm |
It went very smoothly. Everything popped together nicely and nothing unexpected. I haven't really got a final cost as I did a full service at the same time (all oils etc) but including VAT about £2000 I'd imagine. 2002 90 Td5 Station Wagon
2nd Sep 2018 8:29pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5230 |
Just shy of what I spent on my Rover then, I recon it would have cost a massive fortune if you had a garage do it Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
2nd Sep 2018 8:55pm |
I would imagine so! So much so that it would probably have been cheaper to replace the engine if a garage were doing it.
I had the sump off to steam clean it inside and out (and check the oil pump sprocket bolt) and also painted a few bits in the engine bay to tidy things up a bit. Non of which you can see when the engine cover is fitted 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
2nd Sep 2018 9:21pm |
nice to do those little jobs, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
2nd Sep 2018 11:38pm |
With a new head, new filters and a cleaned out sump etc the oil should stay cleaner for far longer 2002 90 Td5 Station Wagon
3rd Sep 2018 7:35am |
Best way, I did the same thing, I went as far in replacing the thermostat housing and pipe. Just to make sure all the coolant was clear. I tell you what the through grafty, Mine started having other problems, It started to blow random fuses then it started to pop the fan fuses for the rad. I had two fans that worked off different systems MPI and SPi, and both kept blowing! We couldnt work out why, it was like the car had a mind of its own! I had to get shot in the end, i was nearly close of spending another 1k on diagnostic. That would have pushed the car into the 2k marker, I had already spent 10k on building the car, and i wasnt going to go any further with it. As it was starting to out way the enjoyment of owning it.
Laugh is i could have rebuilt my land rover defender, for the cost of building a street sleeper metro. Pics are here grafty http://www.defender2.net/forum/topic63300.html Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
3rd Sep 2018 12:36pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10859 |
Great news grafty Clayton.
3rd Sep 2018 8:59pm |
Definitely a sleeper! My mate had a Rover 200? With the 1.8vvc engine. It went really well, so I bet a car that is lighter again would be rapid! 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
4th Sep 2018 8:59pm |
Yeah it practically drove itself, with it been that light Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
4th Sep 2018 10:40pm |
Just got back from a very successful Nürburg Ring weekend! And I can report that the defender performed very well Will update properly tomorrow after I've compiled the pictures etc 2002 90 Td5 Station Wagon
10th Sep 2018 8:44pm |
Great you had no problems Clayton.
10th Sep 2018 8:54pm |
From the little video clip it really did look like it was going well! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
11th Sep 2018 4:55am |
