Home > Technical > td5 rev counter
Page 8 of 10 <12345678910>
Martin
Site Admin
The switches appear to do different things on different models of their tachos. On later models there is a single calibration switch (number Cool and the other 7 switches configure the pulses per rev of the input.
This makes sense given what the guys have said above about switches 1 and 2 being set to "ON" along with switch 8 "ON" by default.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #724758 22nd Aug 2018 8:55am
dobbo
United Kingdom 2004 Defender 130 Td5 HCPU Chawton White
Hi guys I have sent my tacho back to be checked out,
I don't have oscilloscope available so CAI are going to 're check the tacho for me
Will keep you posted.
Post #724779 22nd Aug 2018 10:14am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Clive that picture of you reading the ecu where it says tachometer : enabled. Is that a function you can enable/disable or is it always enabled?
Post #724799 22nd Aug 2018 12:58pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
No, it appears to be permanently enabled, certainly can't change it with the Nanocom. I believe it's written into the basic ECU configuration.
Post #724800 22nd Aug 2018 1:00pm
Martin
Site Admin
Can anyone answer the "spare/unused wires" question above?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #724802 22nd Aug 2018 1:06pm
dorsetsmith
Banging Head
Post #724805 22nd Aug 2018 1:27pm
dorsetsmith
Post #724806 22nd Aug 2018 1:29pm
GerardTd5
Netherlands 2001 Defender 90 Td5 CSW Epsom Green
I also had two wires left over, the sama as Clive; a red and a red/blue. About these two wires, there is nothing mentioned in the fitting instruction.
Post #724809 22nd Aug 2018 1:48pm
dorsetsmith
The wire appear to do different things on different models of their tachos. red/blue wire on different models for coil low side distributor side)petrol engine and white/ black wire for ECU or W on ALT diesel engine , you will find that it has been adapted for this job
SEE page 9 Arrow Rolling Eyes
Post #724847 22nd Aug 2018 3:31pm
chip butty
United Kingdom 2006 Defender 90 Td5 CSW Java Black
Hi, just bought a CIA rev counter from Rimmers.
I saw all the problems that everyone was having & thought that I had better test it before taking apart the dashboard.
The rev counter goes full sweep to test , but has no pulse.
Post #725284 24th Aug 2018 6:05pm
GerardTd5
then there are now five with an error. Have you already had contact with Rimmers ?
Post #725302 24th Aug 2018 7:38pm
rallysteve
Has anyone tried Martin's pull-up resistor?
Post #725303 24th Aug 2018 7:42pm
LandymanStefan
I'm doing it this weekend guys! 👍
Post #725305 24th Aug 2018 7:54pm
LandymanStefan
All hail Martin Bow down
Post #725323 25th Aug 2018 7:40am
LandymanStefan
I will email CAI telling them they're wrong after them telling me there is no need for a pull up.
Maybe you don't need it on vehicles with abs but vehicles without definitely do need it.
Post #725324 25th Aug 2018 7:42am
