![]() | Home > Technical > td5 rev counter |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
The switches appear to do different things on different models of their tachos. On later models there is a single calibration switch (number
![]() This makes sense given what the guys have said above about switches 1 and 2 being set to "ON" along with switch 8 "ON" by default. ![]() ![]() |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Clive that picture of you reading the ecu where it says tachometer : enabled. Is that a function you can enable/disable or is it always enabled?
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
No, it appears to be permanently enabled, certainly can't change it with the Nanocom. I believe it's written into the basic ECU configuration.
Can anyone answer the "spare/unused wires" question above?
![]() Last edited by dorsetsmith on 22nd Aug 2018 2:30pm. Edited 1 time in total |
![]() Click image to enlarge ![]() Click image to enlarge |
GerardTd5 Member Since: 03 Aug 2016 Location: almost Germany Posts: 44 ![]() ![]() ![]() |
I also had two wires left over, the sama as Clive; a red and a red/blue. About these two wires, there is nothing mentioned in the fitting instruction.
The wire appear to do different things on different models of their tachos. red/blue wire on different models for coil low side distributor side)petrol engine and white/ black wire for ECU or W on ALT diesel engine , you will find that it has been adapted for this job
SEE page 9 ![]() ![]() Last edited by dorsetsmith on 28th Aug 2018 6:57pm. Edited 2 times in total |
chip butty Member Since: 12 Mar 2018 Location: manchester Posts: 9 ![]() ![]() ![]() |
Hi, just bought a CIA rev counter from Rimmers.
I saw all the problems that everyone was having & thought that I had better test it before taking apart the dashboard. The rev counter goes full sweep to test , but has no pulse. |
then there are now five with an error. Have you already had contact with Rimmers ?
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Has anyone tried Martin's pull-up resistor?
Steve 02' 110 TD5 Double Cab Rebuild Thread |
I'm doing it this weekend guys! 👍
All hail Martin
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
I will email CAI telling them they're wrong after them telling me there is no need for a pull up.
Maybe you don't need it on vehicles with abs but vehicles without definitely do need it. |
