Home > Technical > td5 rev counter |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2108 |
Very nice job Clive
And excellent research and results on the part of other forum members |
1st Aug 2018 8:40pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6103 |
If (like Stefan above) you already have the grey wire in place in the loom, then how do you connect to it (seeing as it's wired into a plug)
There must be a jumper lead out of the warning light cluster somewhere to link to the rev counter? |
2nd Aug 2018 6:39am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6612 |
Get a terminal for the matching grey connector which is on the instruments loom (PaulMc does the terminals).
Or cut the white/slate and extend to the rev counter directly or add your own connector. The warning lights are connected separately through two smaller black connectors - these don't have any signals on them to do with the instruments. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
2nd Aug 2018 7:08am |
OK cheers. I just wondered how it was done from the factory. if they had a jumper loom available or the Td5 dash had a separate rev counter sub-loom hanging off the main one
3rd Aug 2018 4:22pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Just waiting for my connector from Paul mc now... got the rev counter in and it powers up just haven't got the signal connected yet. Does anyone know what voltage to expect from the signal output? I checked with a meter and I was only getting 0.19v when I revved it a little bit it would roseto around 0.3 but I didn't give it a bootfull. Seems a bit low to me....
4th Aug 2018 7:21am |
You won't get a measurable reading with a meter like that due to the way the ECU generates the signal.
It's not a varying voltage signal, it is varying frequency, and requires a "pull up" which is done in the rev counter. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
4th Aug 2018 7:41am |
Ah right I'll have to wait until I get my connector then, although it didn't come today so I won't be able to do it until next weekend
4th Aug 2018 8:07am |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 502 |
Stefan,
Sorry to hear that your crimped terminal and cable wasn't delivered today I did post it yesterday, by 1st class post. Anyway, when it does arrive, you'll need to unlock the connector housing before you can insert the new terminal. This picture sequence shows a connector from the same series - Lift latches on each end of terminal lock (you'll only need to do this for one row) Click image to enlarge Click image to enlarge Open terminal lock Click image to enlarge Insert terminal(s), crimped side towards outer side of connector housing Click image to enlarge Click image to enlarge Click image to enlarge Close terminal lock Click image to enlarge Engage latches Click image to enlarge . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
4th Aug 2018 2:08pm |
Nooo don't be sorry about it not arriving! I wasn't expecting it to in one day but I was hoping it would. Can't thank you enough for the instructions and the connector!
The forum working at its best |
4th Aug 2018 2:42pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
Just found this post. Will look into it once I'm back from my holidays. Top work! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
4th Aug 2018 4:37pm |
GerardTd5 Member Since: 03 Aug 2016 Location: almost Germany Posts: 44 |
Hi,
Try to connect the tachometer. In this case it is a 90 Td5, my 2001, with abs and tc. If I have understood correctly, the white / black wire must be connected with yellow / pink wire that runs from pin 19 to the abs module. My question is whether it is the yellow / pink wire as marked on the photo with the blue circle. Click image to enlarge Thanks GerardTD5 |
6th Aug 2018 1:43pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
The yellow/pink wire referred to goes from C0658-13 on the ECU to the speedo, it appears to carry the road speed pulse signal, not the engine speed from C0658-19 to ABS.
Confusing to have more than one of the same colour wires with different functions Looks like you're stuck with running the complete new wire from ECU to Tacho |
6th Aug 2018 4:48pm |
Clive, that's what it looks like. I had hoped it was easier; I misinterpreted the pictures of Paul MC and LandymanStefan.
What I can still do is see which color wire pin 19 is and try to find behind the dashboard and then connect it to the white / black. Thanks anyway. GerardTd5 |
6th Aug 2018 5:35pm |
Unfortunately, the wire from pin 19 to the ABS module is also yellow/pink, however, with the ABS controller being under the seatbox along with the engine ECU, that connection doesn't go outside of the seatbox.
That's what I meant about confusion over the same colour wires with different functions. |
6th Aug 2018 5:51pm |
