Home > Technical > td5 rev counter |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6613 |
The switches appear to do different things on different models of their tachos. On later models there is a single calibration switch (number and the other 7 switches configure the pulses per rev of the input.
This makes sense given what the guys have said above about switches 1 and 2 being set to "ON" along with switch 8 "ON" by default. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
22nd Aug 2018 8:55am |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Clive that picture of you reading the ecu where it says tachometer : enabled. Is that a function you can enable/disable or is it always enabled?
22nd Aug 2018 12:58pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
No, it appears to be permanently enabled, certainly can't change it with the Nanocom. I believe it's written into the basic ECU configuration.
22nd Aug 2018 1:00pm |
Can anyone answer the "spare/unused wires" question above? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
22nd Aug 2018 1:06pm |
22nd Aug 2018 1:27pm |
22nd Aug 2018 1:29pm |
GerardTd5 Member Since: 03 Aug 2016 Location: almost Germany Posts: 44 |
I also had two wires left over, the sama as Clive; a red and a red/blue. About these two wires, there is nothing mentioned in the fitting instruction.
22nd Aug 2018 1:48pm |
The wire appear to do different things on different models of their tachos. red/blue wire on different models for coil low side distributor side)petrol engine and white/ black wire for ECU or W on ALT diesel engine , you will find that it has been adapted for this job
SEE page 9 Last edited by dorsetsmith on 28th Aug 2018 5:57pm. Edited 2 times in total |
22nd Aug 2018 3:31pm |
chip butty Member Since: 12 Mar 2018 Location: manchester Posts: 8 |
Hi, just bought a CIA rev counter from Rimmers.
I saw all the problems that everyone was having & thought that I had better test it before taking apart the dashboard. The rev counter goes full sweep to test , but has no pulse. |
24th Aug 2018 6:05pm |
then there are now five with an error. Have you already had contact with Rimmers ?
24th Aug 2018 7:38pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Has anyone tried Martin's pull-up resistor?
Steve 02' 110 TD5 Double Cab Rebuild Thread |
24th Aug 2018 7:42pm |
I'm doing it this weekend guys! 👍
24th Aug 2018 7:54pm |
All hail Martin
25th Aug 2018 7:40am |
I will email CAI telling them they're wrong after them telling me there is no need for a pull up.
Maybe you don't need it on vehicles with abs but vehicles without definitely do need it. |
25th Aug 2018 7:42am |
