Home > Technical > td5 rev counter
Page 10 of 10 <12345678910
Clive
Well done Chip butty and Stefan Thumbs Up
Just a shame that CAI didn't include that vital info on their installation sheet, would have saved everyone a lot of bother Evil or Very Mad
Post #725852 28th Aug 2018 5:51pm
chip butty
United Kingdom 2006 Defender 90 Td5 CSW Java Black
Hi Gerard Td5
My 90 does not have ABS. there was no wire on pin 19.
Hope this helps.
Post #725912 28th Aug 2018 9:15pm
GerardTd5
Netherlands 2001 Defender 90 Td5 CSW Epsom Green
Hi,
Last Monday I received an answer from the supplier of the rev counter. A long story short:
We have tested your tacho this morning, and it does not function.
Also on Monday a rev counter was sent to me that was delivered today with DPD.
It was now plug and play, just testing, the wiring was already there Very Happy . Guess what, it does function. Thumbs Up Thumbs Up
GerardTd5
Post #728656 12th Sep 2018 7:08pm
GerardTd5
I hope that all rev counters now function. It is suddenly no longer a topic. There were more rev counters that did not work, I am only curious about the experience of the others.
Gerard90Td5
Post #733453 7th Oct 2018 1:32pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I've still not bought one because I was waiting for more people to say they sorted it before coughing up 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #733473 7th Oct 2018 4:13pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Mine works now too with the new wiring configuration which included the use of the internal pull up resistor on my non abs td5
Post #733487 7th Oct 2018 6:21pm
M94PUMA
Hi all, sorry to drag up this old post.
Has anyone fitted one recently made by smith gauges from rimmer bro’s??
I’ve got it wired up correctly as in the previous page,
Red/blue-----------------------pulse from pin 19
red-----------------------------ign. live 12v
green--------------------------ign. live 12v
black---------------------------earth
red/white----------------------gauge illumination 12v from other gauge or side lights
No white/black cable in this plug.
however,
The rev counter doesn’t move at all, main problem one. Have run the wire direct from the ecu (even though I’ve got the cable fitted up to the dash loom from factory!)
Second problem, the illumination of the gauge works without the ignition on, when ignition is switched on, the illumination of the gauge turns off.
All wiring has been check over numerous times, and tested with a multimeter.
Post #943475 22nd Feb 2022 6:34pm
M94PUMA
Gauge is on its way back to rimmer bros. Who will return it to Smiths/ Caerbont who make them. Must be a faulty unit..
Post #943558 23rd Feb 2022 5:44pm
BullzeyeTD5
United Kingdom 2001 Defender 90 Td5 CSW Epsom Green
Hey buddy, just wondering what your final fix was and is everything still okay? Hopefully you will still reply Smile
Post #1020864 11th Jan 2024 10:55pm
Register
Everything you need to know is on here.
&t=438s
At least I hope so as I've just spent a whole £17.68 on this quality item.
https://www.ebay.co.uk/itm/314487483380
Pete Everything's a hammer.
Post #1021422 16th Jan 2024 6:30pm
