Home > General & Technical (L663) > NEXT LAND ROVER DEFENDER |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Maybe the new ones will be a bit less expensive in Holland...
Click image to enlarge |
10th Aug 2018 3:21pm |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1432 |
That's 4 times the US price! 33,990 plus tax |
10th Aug 2018 3:30pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17473 |
I know why they did it, but disagree with every part of your last sentence. |
10th Aug 2018 4:45pm |
pcoote Member Since: 01 Aug 2010 Location: Oxford Posts: 83 |
Sounds good, can I also suggest a couple of additions to the above; 1) 2 front opening vents below the windscreen, with a fly strainer. 2) Mechanical high/low ratio gear box |
10th Aug 2018 5:34pm |
skyrover Member Since: 14 Feb 2014 Location: Northumberland Posts: 17 |
Please explain why. Jeep has had fully functioning full time 4wd systems in it's products since the 80's yet has stuck with 2wd/4wd in it's hard-core offroader |
10th Aug 2018 6:37pm |
"Sounds good, can I also suggest a couple of additions to the above;
1) 2 front opening vents below the windscreen, with a fly strainer. 2) Mechanical high/low ratio gear box" While a series 3 with a v8 engine swap was fun in the 1980s, time really has moved on. If that's what people want today, it is still possible to build one. I'd agree with a mechanical high/low gearbox selection lever though and a proper handbrake. No need to over complicate things that work ok. |
10th Aug 2018 6:58pm |
Ramajama Member Since: 28 Jul 2016 Location: Heartland, ‘Murica Posts: 109 |
Wranglers are very over priced. The brand is so profitable that it drawrfs it’s sister companies in profit margin. I don’t have a single problem with healthy margins but I find Wranglers very hard to justify. They have very low towing and payload ratings and they’re pretty much useless for anything other than off roading or daily driving. For a lot of people that fits the bill but I need more out of a vehicle. The new Defender does have to half world beating tow ratings but I hope It has decent capacities at least. |
11th Aug 2018 3:21pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4218 |
Have Jeep answered our prayers?...
https://www.instagram.com/p/BmUwa2DHYFU/ 2007 110 TDCi Station Wagon XS |
11th Aug 2018 6:11pm |
It's well known in the States that a Jeep pickup is due in 2019.
Engine options include a 3.0 V6 diesel that will also be available in the Wrangler 4dr. Not sure if either of them will be available in Europe. This forum is very well connected, with lot of info from inside the factory, like the chassis frame pictures. Maybe the forum is run from inside FCA, stoking interest in new products? https://www.jeepscramblerforum.com/2019-jt-truck-frames-spied/ https://www.jlwranglerforums.com Compare that to JLR that only ever says, "We used to build series 1's, 70 years ago." |
11th Aug 2018 10:01pm |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 |
21st Dec 2018 10:53am |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 575 |
DC100 it is then????? |
21st Dec 2018 2:09pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
However thats an old image
https://www.google.com/search?biw=1536&...amp;tbas=0 130's have feeling's as well you know |
21st Dec 2018 2:45pm |
I bet it is won't be million miles away, looking at the shape of the mule
21st Dec 2018 9:16pm |
milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873 |
21st Dec 2018 11:12pm |
