Home > Puma (Tdci) > Proof of 2.2 being fitted in 2012
Page 1 of 8 12345678>
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Taken this straight from topix, it is the only engine avaliable... We are also losing the ability to buy it in 3 forms; CREW CAB 4 DR, CREW CAB HCPU 4 DR and PICK UP 2DR. I suggest if you want one of those 3 get it now Smile
Jack
Post #71581 18th May 2011 8:36pm
spudfan
Ireland
and that seems to be that.....Well spotted. Thumbs Up 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #71582 18th May 2011 8:42pm
Caterham
i was right after all.
seems I was given the right info many many moons ago!
question is should I have waited? will it be a step in the right direction, a backwards step or simply different?
Post #71586 18th May 2011 9:08pm
pom
fingers crossed for an auto as well.
Post #71587 18th May 2011 9:10pm
110SEB
Guys, forgive me, but what is 'topix'?
Post #71588 18th May 2011 9:11pm
Landie Boy
It is a service from land rover for dealer, I would recommend that you check it out. It's free if you want basic Information like the ability to find your vehicle with it's vin, see recalls etc.... You can also see fitting instructions for assesories.
Hope that helped
Jack
Post #71590 18th May 2011 9:19pm
Landie Boy
At the moment it says it uses the exsisting box
Jack
Post #71591 18th May 2011 9:22pm
Zagato
Why the change to the 2.2 Litre?
Post #71593 18th May 2011 10:00pm
Landie Boy
emissions and stuff like that....
Jack
Post #71594 18th May 2011 10:13pm
dgardel
Italy
Ford costs reduction.
the 2.2 and 2.4 ARE THE SAME motors (only the stroke is different).....
On transit too they will use only the 2.2L so LESS PARTS TO MANAGE
2.4 will use on Ranger (bring to 2.5L) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #71612 19th May 2011 8:16am
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Move to 2.2l was inevitable, because these are the only engines being brought to Euro5 emission standards. It was speculated that the Defender will go there too after Ford announced in Brimingham in April that the Ford Transit will go 2.2l engines only and 2.4l will be discontinued completely.
But i am surprised topix shows the 2011 engine as being 140hp, as it is actually reduced to 122hp in the defender.
Post #71614 19th May 2011 9:05am
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
So someone who wants to buy a new Defender now needs to either get in quick to try and secure a 2.4 or hang back a few weeks to get the 2.2 depending on views on the relative merits and demerits of the engines.
I assume Defenders will keep their N1 status (commercial vehicle) in the uk regardless (although I am only really concerned about the Utility Wagon TBH).
C
Post #71615 19th May 2011 9:06am
dgardel
Italy
NinetyTD4 wrote:
Move to 2.2l was inevitable, because these are the only engines being brought to Euro5 emission standards. It was speculated that the Defender will go there too after Ford announced in Brimingham in April that the Ford Transit will go 2.2l engines only.
2.4L also is EU5 with DPF (see here in italy on transit 140CV), but for the EU emission rate we see the engine - vehicle system, not the only engine stand alone.
The Defender is more heavy respect the Transit ......
The problem is: Ford for engine assembly line optimization reasons will provide only the 2.2L and the volume of the Defender production (and London taxis) is too small for maintain the 2.4 prod. line alive.....
But 2.4 output capabilities are stronger than 2.2 (transit AWD -2011MY is provided only with the 2.4). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #71616 19th May 2011 9:15am
dgardel
Italy
Anyway, the engine is the same and the differences will be so little that the Defender will not change character....
this is the new 2.2L
IID Pro MV License
Post #71617 19th May 2011 9:17am
gazellio
122 bhp is not a lot compared to the other models in the LR range. Is it enough to cope with heavy loads and long hills etc? What is the torque difference?
Post #71618 19th May 2011 9:24am
