Home > Puma (Tdci) > Engine knocking? hydraulic lifters??
Page 1 of 6 123456>
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
My 130 knocks quite a bit when it is cold - I know it is a ford engine - but there is a distinct knock that sounds like a hydraulic lifter or a valve that is not functioning - does the Puma engine have hydraulic lifters ( if they are called that in english). The engine runs well and develops no smoke. The knocking is almost gone after a 30 km run. But before that it is so loud that I can hear it through Iron Maiden......I have recently changed oil ( Havoline 5w30) but the car has been standing still for almost 2 years before I bought it.
Hope everybody will say - its a ford engine Razz or else at tip about what it could be .
Regards
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #71449 18th May 2011 5:13am
CRJ
forgot to tell there is nothing ( almost nothing) below 2000 rpm - but when i go above it sure is there. 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #71450 18th May 2011 5:24am
nickhodgson
Unfortunately, there is a recall about early engines knocking on startup due to something about oil cooling jet springs not working until it warms up? Do a search for the recalls on this forum and see if it fits with your noise.
Post #71468 18th May 2011 8:54am
MK
Could be the cooling jets. But also a faulty injector. If it is out of warranty give it a try-test with a thinner oil or if you can keep the car in a warmer spot overnight. On the other hand, nothing can be said-diagnostic on any cold engine.
I remember you wanted to clean the fuel circuit. Any chance dist went into the injection system? Puma 110" SW
Post #71477 18th May 2011 10:16am
dgardel
Italy
Title: 2.4 Puma Engine Knock Noise.
Type: LD - Defender - All Years - Special Service Messages - Engine
Name / Part No: SSM38792
Info Type: Service Bulletins
Version No: 1
Date Uploaded: 21 Jul 2008
Models: LD - Defender
Last Modified: 21-JUL-2008 09:44
Category: Engine
Symptom: 497000 Engine Noise
Content Issue: Heavy audible knocking heard on start up.
Cause: On start up oil pressures can cause the piston cooling jets, (PCJ), to latch into a zero flow condition. Due to hysteresis effect in design the jets do not unlatch until the engine is warm and the oil pressures lower again. During this time with no pressurized oil jet flow to the lower pistons / cylinder bores, overheat and scuff conditions / damage can occur.
Action: Replace the engine assy but ensure only engines post serial # ELD00080707063602 are used.
This condition will not occur on vehicles post assured Vin# 9A767162.
Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed.
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #71484 18th May 2011 11:31am
CRJ
I am not sure i understand the service bulletin correct - my car has SALLDKHS88A753704 - does that involve it? I am out of warranty so hope not.....
Regards
Puma 130 - 08- sold
110 CC 2003
Post #71491 18th May 2011 12:39pm
MK
3 years of warranty. So check the dates. Puma 110" SW
Post #71492 18th May 2011 12:47pm
CRJ
i know it is 3 years but I imported it from Germany - and the servicebook is non existing......
But one question - if it was this condition would I then not be able to hear the knocking at idle when cold - there is none. 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #71496 18th May 2011 1:01pm
MK
ummmm. IMHO
1) try to get the book via dealer. If you did not do any of the services with a LR approved shop, then.....no way.
2) how about a clogged (FU) injector. The noise is from 1 or more cylinder? Try to scan the engine. Puma 110" SW
Post #71497 18th May 2011 1:09pm
spudfan
Ireland
Was there not an ECU update to help with this problem? If you could contact Land Rover customer services they could tell you what recalls or updates are applicable to your model and whether they have been carried out on your vehicle or not.Regards being out of warranty I would guess that anything like updates or recalls would still be covered as that is a problem at there end.If the knocking is not as stated in the bulletin I am almost sure they had an ECU upload for this. If I am wrong it will not be long before someone here corrects me! Anyway contact customer services for a record of what's been done to your vehicle. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #71499 18th May 2011 1:30pm
CRJ
Thanks a lot for all the replies. As it is now, I have talked to Rover Denmark - they say all recalls will be fixed regardless of servicebook +3 years etc. My car has one recall for the brakeshoe..and one for the ECU ( something about the engine " jumping" when cold.
I also went by a Ford dealer - the chief mechanic said that it was something in the engine management system that needed to be reset. It would take a couple of hours - because the " something" had to be reset and then the engine needed to selfadjust again. Then they also recommended an injectorcleaning - what they do is they disconnect fuel in and out, connect 1 litre of something ( i dont know what) under pressure to in and out and let the engine run on that. He said that you could almost always hear the change when it was half used.
We do not have a lot of defender Pumas in Denmark, so I guess I will rely on Ford - they said right away what needed to be done - had done it many times before.
Will post when I know more.
Regards
Puma 130 - 08- sold
110 CC 2003
Post #71504 18th May 2011 2:09pm
dgardel
Italy
Regards
CRJ
Yes yours is a 2008MY (like mine, drive and enjoy it) and the Service Bulletins told us that only from MY2009 with S/N starting from 767162 should be ok.....
Mine ha 65000 km now and it runs well...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #71505 18th May 2011 2:15pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Just had a look for you, it has two recalls
Visit http://topix.landrover.jlrext.com/topix/vehicle/index
Jack
Post #71508 18th May 2011 2:30pm
Merlin
Mine's 7a750278, should I worry?
Merlin
Post #71552 18th May 2011 6:23pm
RED-DOT
I called LRCS today and after an hour they answered and the call centre proffesional indicated all have been done that were in the affected builds. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #71556 18th May 2011 6:33pm
Page 1 of 6 123456>
