![]() | Home > Puma (Tdci) > Engine knocking? hydraulic lifters?? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4754 ![]() ![]() |
Don't think FB spec is good for the Puma. Needs to be FC as I have been told the Puma has a catalytic converter. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Happy for you ![]() Warranty work or you must pay for it? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2458 ![]() ![]() ![]() |
![]() ............................................................. Earth first. Other planets later |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 ![]() ![]() ![]() |
I will take care of them - and use 2 stroke. I am not going to have them changed again, it was not warranty work, and all in all with filterchange etc. it was too close to 3.000 eur.
Now the only little problem is, that the injectors need to be "fine" adjusted - they needed an update on their computer to do it - do not know how much it changes the way the engine is running. Regards CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
I know it is a bit off topic, but today I added a dash of 2 stroke when putting gasoline on my old 88´´, wauw what a difference - the engine sounds sooo much better
![]() Regards CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
Eric L Member Since: 16 Aug 2007 Location: IN93uc Posts: 15 ![]() ![]() ![]() |
Hi,
Same issue on my 2007 110 and 105000km three weeks ago , fixed by 4 news injectrors. ![]() Click image to enlarge One of them was completely distorted : ![]() Click image to enlarge |
Mine is on 130.000 km now - and a broken engine - hole in one piston probably due to injector not working properly - make sure it is changed in time…
I hope pistons are OK !
The engine has not been opened ... I start to save money to buy a new engine |
I do not think you need to worry - my injectors was changed at 45.000 km… now it is on 130.000 km. Think i noticed a faint knocking again for the last 5.000 km - but only when cold - thought nothing of it - until now
![]() Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
Do you change your engine ?
Here a swap with a refurbished engine is 12000 Euros. If I make 85000 km more , I will be happy. Less than 18000km/year . I live near Lourdes , it could be helpfull ![]() Last edited by Eric L on 5th Jan 2014 6:13pm. Edited 1 time in total |
I haven´t changed it yet. I can get a transit engine for around 2.000 eur - but there is 4 different types of engines - still haven´t figured out which one is the right
The right type is 244DT
Here is a 2008 Defender engine but 4690 euros: ![]() http://www.leboncoin.fr/equipement_auto/590295754.htm Sold by PRO in Europe. Here an other rrefurbished : http://www.ebay.fr/itm/2008-Landrover-Land...1160313505 "244dt motor" in google and make your choice ![]() . |
Update on my engine - ALL 4 pistons cracked - piston on cylinder one has a fine 15 mm. hole right through - no wonder it was smoking like h… Can´t help wondering if my engine was one of them who should have been changed? New injectors at 45.000 due to knocking on startup and now 4 dead pistons at 130.000 ??
New original pistons is about 600 € ex vat. a piece ![]() Or alternatively the engine code for the transit engine that fits in the defender - seems to be 4 different types. Best regards CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
![]() ![]() ![]() Question is - how much does pump calibration and injector learning affect the engine? I run with the original ecu - just plugged in new engine and drove off without problems - do I need to have it plugged in and have all the calibration etc. done?. No remap or similar - never again.. ![]() Best regards CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
