![]() | Home > Maintenance & Modifications > Grease points |
Jim1988 Member Since: 26 Oct 2017 Location: Derbyshire Posts: 256 ![]() ![]() |
It’s a 2010 2.4 90, if that makes any difference. Thanks Jim.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20765 ![]() ![]() |
Door hinges and stays with white lithium. 3in1 aerosol with applicator I find is best for this. Also bonnet hinges and bonnet opening assembly. (Need to do the latter on mine.) door catches. ACF50 has its place also in plenty of places such as the bonnet hinge to bulkhead weld.
Regarding your props, are you sure there is not a hole for the nipple on the slider area? ACF50 under all cappings is a good idea too WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Thanks will add them to tomorrow’s to do list then ☺️
Pretty sure, I brushed my hand all over the prop and couldn’t feel anything, the uj’s were obvious, so would have thought the props to be the same? Will have another look tomorrow just incase I’ve missed something. Just been reading about the swivels, so will also check them. Do anything like the track rod end have grease points etc? Can you tell I just want to use my new toy 😂 Thanks Jim. |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Take the wheels off and grease the areas that contact the drive flanges - a non melting grease like copper grease is best.
Track rod ends can't be greased as standard, unless someone has fitted ends with nipples. |
They could be missing, but possibly unlikely that both nipples are at the same time. Later models I think didn't have them on the slider and were sealed for life and I thought this was on 2.2's. But don't quote me on this, sketchy memory regarding that. Worth checking again for a hole but if you don't find any still fir a threaded nipple then there weren't any fitted. UJ nipples seem to disappear more often or at least on mine they did. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
my 2010 2.4, doesn't have any nipples or holes for the on the sliders. But it could of course have had both prop shafts replaced with later ones.
Thanks, that’s today’s home work sorted then 👍🏻 Thanks Jim.
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
my 2011 dosn't have slider nipples DEFENDER 90 TDCI XS,
+1 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Don’t forget to grease these obvious nipples here. Can’t miss ‘em, 4 on a 90, 8 on a 110.
![]() ![]() Click image to enlarge Oh, and for the hubs, surely if you have alloy wheels, ceramic grease might be better than copper slip. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Regarding the prop slider grease nipples mine mine does have them but is a 2007 (57).
2.4 TDCi. So looking at the number of you who said your 2.4 doesn't have them I'd imagine around 2008 - 2010 later type props were used at the factory. I doubt that three or more of you had the props swapped out. There was also the recall regarding missing nipples so there are a few options open, but my guess is at some point LR changed props to greaseable UJ's only and sealed for life slider. Quite interesting. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945 ![]() ![]() ![]() |
Steve, my 90 is a 2008 model. Slider grease nipples present and correct (and freshly greased)
