Home > Maintenance & Modifications > Grease points
Jim1988
Grease points
I’ve just greased my uj’s, can’t do the props as there is not nipples on mine Big Cry
Landy now drives much smoother, but I’m just curious to what other places I can/should grease up? Trying to find some sort of list, but having no luck, search function doesn’t seem to come up with anything apart from props/uj’s.
Some advice much appreciated.
Thanks Jim. Thanks Jim.
Post #713324 19th Jun 2018 10:08pm
Jim1988
It’s a 2010 2.4 90, if that makes any difference. Thanks Jim.
Post #713325 19th Jun 2018 10:10pm
Door hinges and stays with white lithium. 3in1 aerosol with applicator I find is best for this. Also bonnet hinges and bonnet opening assembly. (Need to do the latter on mine.) door catches. ACF50 has its place also in plenty of places such as the bonnet hinge to bulkhead weld.
Regarding your props, are you sure there is not a hole for the nipple on the slider area?
ACF50 under all cappings is a good idea too WeWillWin🇬🇧🇺🇸
Post #713329 19th Jun 2018 10:14pm
Jim1988
Thanks will add them to tomorrow’s to do list then ☺️
Pretty sure, I brushed my hand all over the prop and couldn’t feel anything, the uj’s were obvious, so would have thought the props to be the same? Will have another look tomorrow just incase I’ve missed something.
Just been reading about the swivels, so will also check them.
Do anything like the track rod end have grease points etc? Can you tell I just want to use my new toy 😂 Thanks Jim.
Post #713334 19th Jun 2018 10:20pm
zsd-puma
Take the wheels off and grease the areas that contact the drive flanges - a non melting grease like copper grease is best.
Track rod ends can't be greased as standard, unless someone has fitted ends with nipples.
Post #713341 19th Jun 2018 10:34pm
They could be missing, but possibly unlikely that both nipples are at the same time.
Later models I think didn't have them on the slider and were sealed for life and I thought this was on 2.2's.
But don't quote me on this, sketchy memory regarding that.
Worth checking again for a hole but if you don't find any still fir a threaded nipple then there weren't any fitted.
UJ nipples seem to disappear more often or at least on mine they did. WeWillWin🇬🇧🇺🇸
Post #713358 19th Jun 2018 11:58pm
zsd-puma
my 2010 2.4, doesn't have any nipples or holes for the on the sliders. But it could of course have had both prop shafts replaced with later ones.
Post #713360 20th Jun 2018 12:11am
Jim1988
Thanks, that’s today’s home work sorted then 👍🏻 Thanks Jim.
Post #713361 20th Jun 2018 5:59am
LR90XS2011
my 2011 dosn't have slider nipples DEFENDER 90 TDCI XS,
Post #713363 20th Jun 2018 6:23am
MartinK
+1 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #713367 20th Jun 2018 7:30am
ericvv
Don’t forget to grease these obvious nipples here. Can’t miss ‘em, 4 on a 90, 8 on a 110. Cool
Oh, and for the hubs, surely if you have alloy wheels, ceramic grease might be better than copper slip. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #713470 20th Jun 2018 5:36pm
Regarding the prop slider grease nipples mine mine does have them but is a 2007 (57).
2.4 TDCi.
So looking at the number of you who said your 2.4 doesn't have them I'd imagine around 2008 - 2010 later type props were used at the factory.
I doubt that three or more of you had the props swapped out.
There was also the recall regarding missing nipples so there are a few options open, but my guess is at some point LR changed props to greaseable UJ's only and sealed for life slider.
Quite interesting. WeWillWin🇬🇧🇺🇸
Post #713476 20th Jun 2018 5:59pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Steve, my 90 is a 2008 model. Slider grease nipples present and correct (and freshly greased) Thumbs Up
Post #750111 9th Jan 2019 12:01am
