Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
I get it from autopaint international on Manchester road next to bu garage. Ray My build thread http://www.defender2.net/forum/topic17615.html |
9th May 2018 9:10pm |
The helicopter tape for the side steps didn't go well to many curves and I couldn't get rid of some air bubbles so plan b is stone chip on the underneath, back and brackets and hope the wax inside protects well. I've added an extra drain hole underneath before painting so I'm hopeful this will get any water out quickly. Ray
12th May 2018 7:03pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Have you considered Raptor or X-line? Buzzweld do a huge range of good product, might be worth a look? James
12th May 2018 8:03pm |
I've seen a couple of those but picked up the stone chip today so I'll throw it on for now. I'll probably stick these steps on until they start to rust then buy some stainless ones. Ray
12th May 2018 8:10pm |
Yeah, I used the same method of soap solution, squeegy and heat gun but with the size of the piece I was trying to fit and the amount of different curves of the steps I just couldn't get it to work so plan b was started today.
All masked up, stone chipped and waxed with bilt hamber up inside. Click image to enlarge I'll give them another wax inside once this lot has set up a bit then start putting them back together for fitting. Ray My build thread http://www.defender2.net/forum/topic17615.html |
13th May 2018 9:25pm |
The big rivnut tool had to come out for the stainless rivnuts on the steps as the hand pliers wouldn't pull them tight
Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
15th May 2018 7:36pm |
I need to polish up the bits where the masking tape was but the new ones look a bit better than the old ones
Click image to enlarge Click image to enlarge Having had a good look at the old ones it's only really surface rust so I'll sand them back and por15 them then stick them on eBay Incase someone wants some cheap steps. Ray My build thread http://www.defender2.net/forum/topic17615.html |
28th May 2018 10:32pm |
Looks much smarter, just need to wash it now.
Click image to enlarge Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
29th May 2018 4:40pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1763 |
I need to get some all black f & i, they are my fave. Nice job
29th May 2018 6:17pm |
Ray
29th May 2018 6:29pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10830 |
Good job done there Ray, looks so much better now Clayton.
30th May 2018 9:54pm |
thank you, I've got a couple of interesting jobs to hopefully get done in the next couple of months so should be some more pics coming soon. Ray
30th May 2018 11:18pm |
Looking forward to seeing the pic's as and when Clayton.
1st Jun 2018 7:06pm |
I decided it was time for all four tyres to match
Click image to enlarge Click image to enlarge Anyone want to buy two conties with loads of tread still on them? Ray My build thread http://www.defender2.net/forum/topic17615.html |
15th Jun 2018 10:47pm |
