Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 62 of 81 <123 ... 616263 ... 798081>
mk1collector
ginjez wrote:
Where are you buying the paint from Ray?
I get it from autopaint international on Manchester road next to bu garage. Ray
My build thread
Post #706304 9th May 2018 9:10pm
mk1collector
The helicopter tape for the side steps didn't go well Big Cry to many curves and I couldn't get rid of some air bubbles so plan b is stone chip on the underneath, back and brackets and hope the wax inside protects well. I've added an extra drain hole underneath before painting so I'm hopeful this will get any water out quickly. Ray
My build thread
Post #706797 12th May 2018 7:03pm
JOW240725
Have you considered Raptor or X-line? Buzzweld do a huge range of good product, might be worth a look? James
Instagram @suffolk_rovers
Post #706812 12th May 2018 8:03pm
mk1collector
Thumbs Up I've seen a couple of those but picked up the stone chip today so I'll throw it on for now. I'll probably stick these steps on until they start to rust then buy some stainless ones. Ray
My build thread
Post #706815 12th May 2018 8:10pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Just had to google what helicopter tape Embarassed and I have some from when I had the non LR in the garage.
How did you apply it? I use a soap solution, squeegy, and heat gun. I have some gloss black wrap if you wanted to try some.
Post #706980 13th May 2018 8:08pm
mk1collector
Yeah, I used the same method of soap solution, squeegy and heat gun but with the size of the piece I was trying to fit and the amount of different curves of the steps I just couldn't get it to work Big Cry so plan b was started today.
All masked up, stone chipped and waxed with bilt hamber up inside.
I'll give them another wax inside once this lot has set up a bit then start putting them back together for fitting. Ray
My build thread
Post #707005 13th May 2018 9:25pm
mk1collector
The big rivnut tool had to come out for the stainless rivnuts on the steps as the hand pliers wouldn't pull them tight Rolling with laughter
 Ray
My build thread
Post #707387 15th May 2018 7:36pm
mk1collector
I need to polish up the bits where the masking tape was but the new ones look a bit better than the old ones Rolling with laughter
Having had a good look at the old ones it's only really surface rust so I'll sand them back and por15 them then stick them on eBay Incase someone wants some cheap steps. Ray
My build thread
Post #709674 28th May 2018 10:32pm
mk1collector
Looks much smarter, just need to wash it now.
 Ray
My build thread
Post #709775 29th May 2018 4:40pm
ginjez
I need to get some all black f & i, they are my fave. Nice job Thumbs Up
Post #709798 29th May 2018 6:17pm
mk1collector
Post #709801 29th May 2018 6:29pm
L110CDL
Good job done there Ray, looks so much better now Thumbs Up Clayton.
Keeper.
Post #710053 30th May 2018 9:54pm
mk1collector
Thumbs Up thank you, I've got a couple of interesting jobs to hopefully get done in the next couple of months so should be some more pics coming soon. Ray
My build thread
Post #710068 30th May 2018 11:18pm
L110CDL
Looking forward to seeing the pic's as and when Wink Very Happy Clayton.
Keeper.
Post #710329 1st Jun 2018 7:06pm
mk1collector
I decided it was time for all four tyres to match Rolling with laughter
Anyone want to buy two conties with loads of tread still on them? Rolling with laughter Ray
My build thread
Post #712560 15th Jun 2018 10:47pm
