Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 63 of 81 <123 ... 626364 ... 798081>
grafty99
Very soothing to my ocd Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #712562 15th Jun 2018 10:54pm
mk1collector
Rolling with laughter mine too Rolling with laughter Ray
My build thread
Post #712563 15th Jun 2018 11:08pm
grafty99
Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #712588 16th Jun 2018 7:49am
mk1collector
Now if only my budget could keep up with my ocd on the rest of the things that need doing Big Cry Ray
My build thread
Post #712602 16th Jun 2018 11:01am
mk1collector
Started the Provent catch can fitting today, first was to drill out some flat bar to fit to the wing support bracket and give it a bit of paint.
Next bolt it all to the provent.
Then bolt it back to the wing.
I’ve already got all the pipes together but I’ll have to fit those tomorrow if it’s dry.
Thanks for looking Thumbs Up Ray
My build thread
Post #712682 16th Jun 2018 8:11pm
L110CDL
Looks a nice and neat job Ray Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #712900 17th Jun 2018 8:01pm
mk1collector
Thank you Thumbs Up should be nice and easy to get to when the filter needs changing too Mr. Green didn’t get round to fitting up the pipe work today though because Father’s Day is more work than a regular Sunday Big Cry Ray
My build thread
Post #712937 17th Jun 2018 9:19pm
L110CDL
Keeper.
Clayton.
Post #712940 17th Jun 2018 9:28pm
mk1collector
Still haven’t got around to finishing the provent but this turned up today.
A nice new centre box. We’re taking my parents on holiday with us this year so I decided to put a silencer back on in place of the straight through pipe to make it a bit quieter for them on the 7/8 hour drive to the ferry. I’m such a good son Rolling with laughter Ray
My build thread
Post #713110 18th Jun 2018 10:12pm
Castillo
Finland
Do this middle a great difference in noise defender 110 td5 2006
Post #713113 19th Jun 2018 4:34am
mk1collector
It’s a lot quieter than a straight through pipe Thumbs Up Ray
My build thread
Post #713131 19th Jun 2018 8:17am
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
An even better son would have done the relaxing Hull crossing so as not to punish them to a slog in a Defender Laughing
Post #713217 19th Jun 2018 4:35pm
mk1collector
I’m not that nice Rolling with laughter Ray
My build thread
Post #713228 19th Jun 2018 5:15pm
mk1collector
While I’m waiting for some bits arriving for the piping for the provent I’ve started fitting some bits that arrived the other day
Some more security bits!
I won’t go into detail of most of it but I got a pic of this fitted.
It took a bit of filing and fettling to get the cowl and wires to all fit in but it looks quite neat now Mr. Green
Every little helps Thumbs Up Ray
My build thread
Post #713541 20th Jun 2018 8:10pm
mk1collector
Went to put new rear pads in today as the last mot advised they were getting low, got everything ready, wheel off, start pulling pads, and the calliper is seized solid on one piston and other piston only just moves Big Cry put it back together and went for a sulk then ordered some new rear calipers Big Cry also found a crack in the brake servo, so what started as new pads and change two bit of brake pipe that had an advisory on the mot has turned into brake pipes, front brake flexis, two rear calipers, new pads all round, a new servo and fluid change Big Cry
Why do we bother with Landrover’s........... Ray
My build thread
Post #713696 21st Jun 2018 3:22pm
