![]() | Home > Maintenance & Modifications > PUMA CLUTCH REPLACEMENT |
^^ Thanks for that info. In this country the regular genuine LR clutch parts alone will cost already £1300 or so.
![]() Will check posses with my dealer next week after they will open up the truck for surgery. Is this also a good occasion to see the state of the drive shaft, and needs be renew that, or just grease if still ok, or replace by the greased Ashcroft version? (I think it is Ashcroft who make that self-oiling version, yes?) Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Ok, new clutch done. Dealer installed a full clutch kit (part nbr LR048731), also a new clutch slave cylinder (part nbr LR068979), and a new slave cylinder adapter (LR068981). The latter was a must to do as the design has changed since my truck was built. All genuine parts obviously. Works a treat again, and sofar no rattling springs.
![]() The good thing is that having gearbox and transfer box off and separated, it allowed dealer to check all drive shafts, and there seems zero wear on all that, and also no red dust as so many later Defenders seem to suffer from. Everything that could be greased was greased again in the process before bolting it all together. Hope I'm ok for the next 88.000 KM. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 5th Oct 2017 5:38pm. Edited 2 times in total |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4773 ![]() ![]() |
Sounds good
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
ter11 Member Since: 28 Oct 2015 Location: Zurich Posts: 26 ![]() ![]() ![]() |
Interested to hear, how this continues... BR, ter
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2464 ![]() ![]() ![]() |
Have the same issue when hot. Brand new friction plate. So unless you have further symptoms I would not worry.
Beyond the ![]() ............................................................. Earth first. Other planets later |
Milmur64 Member Since: 05 Oct 2016 Location: Perthshire Posts: 33 ![]() ![]() ![]() |
Many thanks for your reply - much appreciated.
Regards Jonathan |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
are you sure it's not the gearstick rattling on the shaft? Mine was near silent after I had a new clutch fitted. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
mine clattered more than the old one for a couple of weeks then just stopped and it's been fine since? (about 10k)?
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2450 ![]() ![]() |
I have had a Syncro Ultraspec clutch fitted to my modified 190bhp 2.4 110. lovely light action and nice instant uptake. 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS |
