![]() | Home > Series Land Rovers > And away we go again! S3 V8 project... |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 800 ![]() ![]() |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 761 ![]() |
I've got some scrap door tops here Ian. Both fixed panes intact and one sliding, yours free if of any use to you.
Andrew |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Thanks Andrew, very kind.
I went down to Urchfont yesterday, if only I knew... ![]() I still wouldn’t mind them though as the other side is badly scratched, and could do with a better one! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Dooh, so close!
My number is in Legend, just give me a call if you want come over. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3797 ![]() ![]() |
Hi Ian
That's looking great, few questions... Have you sprayed the panels? (as they look great) Are they XS seats? would (could it take the middle normal seat) Where is the wheel from (steering one) ![]() I like that ![]() |
I know!! ![]() Thank Andrew, I will be in touch. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Hi Scott
I’ve sprayed the doors and door tops (all new) The truck cab, bulkhead, and two outer wing panels, I’m must say the amount of Matt in the paint was spot on, And matched the older panels well. The seats are a straightforward fit, remove the old series seat runners, and bolt later ones straight in. You don’t even need to drill any extra holes. You could easily fit a third seat if you wanted to, I’m going Cubby box. The steering wheel and boss came from eBay, I will find a link for it. Cheers Ian 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10872 ![]() ![]() |
Thats looking just great Ian
Squirdan Member Since: 28 Sep 2013 Location: London Posts: 68 ![]() ![]() |
looks great - brilliant project
you should do these "on commission" |
![]() It can be arranged Dan..... ![]() Wanted, Forward Control Anything considered. |
Spent some time on the 3 today, I’ve not done much recently, but did managed to get some carpet in the cab,
and plumb in the heated seats, i would have liked to have fixed the centre tray in place, but I can’t find the centre panel cover for the seat box. I’ve no idea where its gone? It’s the only part I’ve misplaced! ![]() Very nearly time to put it through for a test, and start using it. ![]() ![]() Click image to enlarge ![]() Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Nice! The covers are easy to lose being flat! You've probably leaned it somewhere and leaned something else over it!
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Maybe the missus has taken it indoor with your teacup and empty biscuit plate?
Looking great! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
![]() Cheers👍🏻 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
