Home > My Defender > Grafty's Td5 90
Page 61 of 124 <123 ... 606162 ... 122123124>
Procta
grafty99 wrote:
110 is having a full re spray, white lettering on the tyres and colour coded roof Thumbs Up
How much is the respray setting you parents back? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #681908 26th Jan 2018 5:06pm
Procta
grafty99 wrote:
As it's Thursday (just) I thought I'd upload a throwback Thursday pic. This is about a week after I finished the defender. So fresh looking Mr. Green
That's not finished Whistle Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #681909 26th Jan 2018 5:07pm
grafty99
I like what you did there Rolling with laughter
As for the defender, it's never finished Rolling Eyes 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #681938 26th Jan 2018 6:58pm
grafty99
Respray cost I would imagine will be similar to mine at about £2,000 Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #681940 26th Jan 2018 6:59pm
Procta
How many times was yours painted? My dads has been re done in the past. But not that well sadly, his is a darker colour than mine. But my dads made things worse, by jabbing at filled holes with screw drivers and weak areas causing most of the bottom panels, where the seat box bolts on to disappear, Rolling Eyes So the rear tub will need a rebuild or a replacement. Not to mention the damage he has done with the lift jack Rolling Eyes My mum spends money trying to tidy it up etc, dad does the opposite Rolling Eyes Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #681944 26th Jan 2018 7:14pm
grafty99
Mine was all original paint before the respray and was taken right back before the respray. It's all been high build primed, base coated then had 4 coats of lacquer.
There is nothing worse than a poorly executed paint job as it can be very time consuming to put right Big Cry
Best thing to do it tackle it panel at a time Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #681978 26th Jan 2018 8:52pm
Procta
its getting some where decent too, That are willing to do the work properly, where I live grafty, Most of the garages have a really bad rep sadly for not doing stuff properly. Id take mine to my local coach works as they deal with insurance right offs etc. Sounds like you have more paint on it now than it did when it left land rover! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #681990 26th Jan 2018 9:32pm
grafty99
Yeah it's hard to find a decent paint shop.
I think landrover would have made the amount of paint on my defender stretch to 3 Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #681992 26th Jan 2018 9:38pm
Procta
My place will do their best to get away on just putting the least amount on that they can get away with on their parts!
Just to save paint and money! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #681995 26th Jan 2018 9:46pm
grafty99
Evil or Very Mad time to find somewhere better Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #681998 26th Jan 2018 10:16pm
grafty99
Finally today (nearly 3 weeks after changing the coolant) I managed to get the last bit of air out of the coolant system on my defender. It was being VERY stubborn!
Symptoms were no heat from heaters at anything below 2k rpm. (Also false over heat displayed on dash once) no matter how much I tried the heater matrix kept holding onto some air.
Today I took the output hose off the heater matrix whilst it was running and managed to get the rest of the air out so I now get toasty air at tickover Mr. Green
Also a quick clean Thumbs Up
1990 Vogue SE
Post #683880 3rd Feb 2018 6:06pm
Procta
My rover metro grafty was a right bitch for bleeding! I think I will have to do the hose pipe trick with the 300 when I come to change the rad. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #683924 3rd Feb 2018 9:06pm
L110CDL
Glad you got to the bottom of your problem there grafty Thumbs Up
Is that quick wash you did so Procta thinks you have done the white lettering Wink Whistle Laughing Clayton.
Keeper.
Post #683934 3rd Feb 2018 9:22pm
ibexman
I thought it was a respray Whistle
Post #683942 3rd Feb 2018 9:45pm
grafty99
Rolling with laughter No mask respray, just wipe off the headlights and windows!
Forget the white letters, go for white all over Laughing
If changing the radiator I would also see if you can find an in line bleed screw to mount in the output hose of the heater. Good for future coolant changes too.
When I install the webasto I shall be doing exactly that Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #683974 3rd Feb 2018 11:15pm
