Home > Puma (Tdci) > Washer jets |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
Centre panel, the bit with the radio.
2nd Mar 2017 7:01pm |
Hendrix Member Since: 04 Oct 2016 Location: North Notts Posts: 103 |
Had a look at chaging the washer pump! Anyone taken a pump or tank out on an aircon 2.2 looks a pain for something so simple.
12th Mar 2017 8:10pm |
Removing the left headlamp Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
12th Mar 2017 9:54pm |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 |
!!! I just got two new LR jets to fit in my Puma 2010 Where can I get these spacers or what could I use...? 2010 Defender 90 HT The longer I live..... The better I was! |
13th Mar 2017 1:57pm |
Headlight out sounds good thanks
13th Mar 2017 3:27pm |
capnjapseye Member Since: 21 Feb 2015 Location: Cornwall Posts: 223 |
Did this on mine today, the biggest problem is the length of the new jets, they are not long enough to allow for a gasket on the outside & a washer on the inside. The washer is necessary on the inside otherwise the brass nut on the jet will pull through the hole on the inside part of the window channel. I ground down a SS washer (& flattened one side) for the inside whilst using a good gob of gack (black gasket maker) for the outside. 2015 90 Hard Top 1998 90 300Tdi - chuffed to have another one 2013 Freelander 2 - for posher trips to the shop 1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it 2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit 2010 90 Hard Top - now sold Ex mil 90 - now sold |
3rd Jan 2018 5:38pm |
When I did this on my '05 110, I just fitted a washer to each new jet that compressed and sealed against the existing oval rubber grommet. Worked a treat.
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
3rd Jan 2018 6:22pm |
Maybe the TD5 bulkhead where the jets go thro is slightly thinner? I’m sure I wouldn’t have got the nut on the back if I’d used your method on my TDCI 2015 90 Hard Top
3rd Jan 2018 7:22pm |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
After concentrating on the new house for some time, it's time again for car
Click image to enlarge It's nice to see the washer jet post is still alive. And after receiving another pm i've decided to produce a couple sets of spacers (4 per set). They will arriving next week. If interested contact me. Kind regards Jack a defender from 1984 pretending to be a puma with a touch of Range Rover |
19th Jan 2018 7:37am |
Garitrude Member Since: 08 Mar 2017 Location: North Posts: 3 |
Hello Jack,
we are interested in 2*4 washer jet spacers for TDCI if you still have them. Were can we send our order and money for delivery to germany. Thank you for your information. Irene and Wolfgang |
25th Sep 2018 1:04pm |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 354 |
Holy Thread ressurrection! Started this seemingly easy job this morning but have hit a snag - the 4x Christmas tree screw things holding that bracket in position will not budge for me. Any helpful tips/simple things I may have missed? No amount of faffing about with screw driver bits in there is budging them. Leaving me with a half removed dash and a not replaced washer jet... |
21st Jan 2020 12:38pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
The things are a pain. Stick a small screwdriver between screw head and Scrivet body. Prise it up and out. Then under the scrivet body to prise that up and out.
I found as you have they will not unscrew being plastic on plastic. The WSM states they are one time use throw away parts. But I have re-used. The bracket isn’t safety critical it’s only a little support to HU rear and air ducting pipes. The HU rear mount rubber is just as much of a pita too! A forked trim tool, ideally metal would help too. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
21st Jan 2020 1:39pm |
Thanks for that - I have a forked trim tool but I managed to snap one tine off! Have something else that should do the trick. Thanks again...
21st Jan 2020 4:53pm |
21st Jan 2020 5:35pm |
