Home > Puma (Tdci) > Washer jets
Page 3 of 5 <12345>
Mac22
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Santorini Black
Can anyone identify what part of the dash needs to be removed to access the jets. Just can't work it out from John's piccy.
Post #606140 2nd Mar 2017 6:59pm
Centre panel, the bit with the radio.
Post #606142 2nd Mar 2017 7:01pm
Hendrix
England 2013 Defender 110 Puma 2.2 USW Santorini Black
Had a look at chaging the washer pump! Anyone taken a pump or tank out on an aircon 2.2 looks a pain for something so simple.
Post #608956 12th Mar 2017 8:10pm
dgardel
Italy
Removing the left headlamp Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #609018 12th Mar 2017 9:54pm
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Tdi4 wrote:
Upto the TD5 the bulkhead has 9mm holes where you can put the jets in. From the Puma there are different and much bigger holes, with an awkward shape. In these holes you can't put the regular jets, therefore i designed a spacer (hopefully i get the foto in this post Wink ) and then you can use the regular jets. And you don't have to change the pump, it's delivering sufficient water. Even when you spray from the front and the back at the same time.
[/img]
Yesss eureka! photo's displayed
Censored Big Cry !!! I just got two new LR jets to fit in my Puma 2010 Where can I get these spacers or what could I use...? 2010 Defender 90 HT
The longer I live..... The better I was!
Post #609144 13th Mar 2017 1:57pm
Hendrix
Headlight out sounds good thanks
Post #609153 13th Mar 2017 3:27pm
capnjapseye
United Kingdom 2016 Defender 90 Puma 2.2 HT Santorini Black
Butchers Boy wrote:
[/img]
Did this on mine today, the biggest problem is the length of the new jets, they are not long enough to allow for a gasket on the outside & a washer on the inside. The washer is necessary on the inside otherwise the brass nut on the jet will pull through the hole on the inside part of the window channel. I ground down a SS washer (& flattened one side) for the inside whilst using a good gob of gack (black gasket maker) for the outside. 2015 90 Hard Top
1998 90 300Tdi - chuffed to have another one
2013 Freelander 2 - for posher trips to the shop
1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it
2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit
2010 90 Hard Top - now sold
Ex mil 90 - now sold
Post #675467 3rd Jan 2018 5:38pm
When I did this on my '05 110, I just fitted a washer to each new jet that compressed and sealed against the existing oval rubber grommet. Worked a treat.
 Darren
Post #675483 3rd Jan 2018 6:22pm
capnjapseye
Maybe the TD5 bulkhead where the jets go thro is slightly thinner? I’m sure I wouldn’t have got the nut on the back if I’d used your method on my TDCI 2015 90 Hard Top
Post #675498 3rd Jan 2018 7:22pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Spacer
After concentrating on the new house for some time, it's time again for car Very Happy
It's nice to see the washer jet post is still alive. And after receiving another pm i've decided to produce a couple sets of spacers (4 per set). They will arriving next week. If interested contact me.
Kind regards Jack a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #679815 19th Jan 2018 7:37am
Garitrude
Germany
Hello Jack,
we are interested in 2*4 washer jet spacers for TDCI if you still have them. Were can we send our order and money for delivery to germany.
Thank you for your information.
Irene and Wolfgang
Post #731098 25th Sep 2018 1:04pm
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
John Fair wrote:
Ref dash not having to come out in a puma- on mine I removed the center console (2 screws, pull to remove clips, remove wiring blocks), I then removed the metal bracket blocking the view of the back of the washer jet ( 8mm bolt, 4x plastic Christmas tree screw things with plugs) and simply tightened the washer jet mount with a 13mm deep socket after pulling pipe off the rear. Hopefully this helps someone. Realistically 15/20mins. Oh and a flashlight.
Holy Thread ressurrection! Started this seemingly easy job this morning but have hit a snag - the 4x Christmas tree screw things holding that bracket in position will not budge for me. Any helpful tips/simple things I may have missed? No amount of faffing about with screw driver bits in there is budging them. Leaving me with a half removed dash and a not replaced washer jet...
Post #811286 21st Jan 2020 12:38pm
The things are a pain. Stick a small screwdriver between screw head and Scrivet body. Prise it up and out. Then under the scrivet body to prise that up and out.
I found as you have they will not unscrew being plastic on plastic.
The WSM states they are one time use throw away parts. But I have re-used.
The bracket isn’t safety critical it’s only a little support to HU rear and air ducting pipes.
The HU rear mount rubber is just as much of a pita too!
A forked trim tool, ideally metal would help too. $W33T $0U7H3RN $UG4R
Post #811294 21st Jan 2020 1:39pm
MussEd
Thanks for that - I have a forked trim tool but I managed to snap one tine off! Have something else that should do the trick. Thanks again...
Post #811328 21st Jan 2020 4:53pm
Thumbs Up $W33T $0U7H3RN $UG4R
Post #811334 21st Jan 2020 5:35pm
Page 3 of 5 <12345>
