Home > My Defender > Grafty's Td5 90
Page 55 of 124 <123 ... 545556 ... 122123124>
L110CDL
They look good, which pic, left or right, fixes to the dash ? just so i can get an idea in my head Wink Clayton.
Keeper.
Post #674580 31st Dec 2017 12:01am
grafty99
The one on the right is in the correct orientation to go into the dash with the nozzle attatched on the underside Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #674585 31st Dec 2017 12:17am
grafty99
Ended up going on a new years eve ride on my motorbike today so some update pics of the vents tomorrow hopefully Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #674777 31st Dec 2017 6:37pm
L110CDL
Thumbs Up Clayton.
Keeper.
Post #674823 31st Dec 2017 9:17pm
grafty99
Got the lower vent nozzles assembled and installed today, I adjusted the design of the nozzle because I thought the previous version aimed the air too low, well unfortunately I think this aims the air too high, right at your face which isn't really ideal. I think version 2 will need some vertical air adjustment control.
Anyway here are the prototypes assembled installed Thumbs Up
As you can see, the base needs to have a larger lip to cover the profile in the dash to finish it better. But not bad for a first prototype Thumbs Up
1990 Vogue SE
Post #674914 1st Jan 2018 11:23am
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Looking excellent!
Normally I would ask what material you are printing in for this sort of application but I don't think there's any risk of a defender heater melting/deforming plastic! Rolling with laughter
Well not on Tdis and Td5s at least, pumas have the opposite problem - it's like having a blowtorch on your leg!! Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #674915 1st Jan 2018 11:27am
grafty99
Tell me about it, when my puma was up to temperature you couldn't hold your hand in front of the top air vents on full heat and fan Shocked
To be fair though a properly adjusted tdi/5 heater is pretty effective. I have to turn mine down once the inside is up to temperature Thumbs Up
Printed it standard PLA Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #674920 1st Jan 2018 11:47am
grafty99
Matt you have an e-mail Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #674927 1st Jan 2018 12:11pm
trickster5000
Just received thanks! Smile I'll let you know how I get on when I get a chance Thumbs Up Matt.
Post #674930 1st Jan 2018 12:14pm
grafty99
1990 Vogue SE
Post #674932 1st Jan 2018 12:16pm
Procta
looking good there grafty Thumbs Up what type of screw are you using for the nozzle? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #674954 1st Jan 2018 2:46pm
grafty99
Thanks Procta Thumbs Up Just a M5 thread cap head. Just something I had laying around. Anything would do it Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #674964 1st Jan 2018 3:35pm
grafty99
Another little mod I've done today is upgrade the springs in my wiper arms. The springs are out of the spare range rovers wiper arms. They are a direct swap and certainly improve the screen pressure!
A few photos for comparison Thumbs Up
Spring pressure before - box lifts all but 10mm of the blade off the screen
Spring pressure after - box only manages to lift half of the blade so quite an improvement I think Mr. Green
Also as you can see in the first picture, the actual pressed steel part of the range rover arm is thicker to prevent flex. I plan to shorten these arms for the defender to take advantage of the thicker material at some point Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #674968 1st Jan 2018 3:43pm
barbel jim
By properly adjusted do you mean the cable on top of the heater box? I have noticed my green one is warmer than new blue one. I have checked the arm is on max adjustment with the Cable , but it's still only slightly warm Big Cry any suggestions appreciated Thumbs Up
Makes a change for no sarcasm Rolling with laughter Rolling with laughter
Post #674995 1st Jan 2018 6:12pm
grafty99
New year new you Jim? Rolling with laughter
Yes the top cable needs to be properly adjusted to make the foam inside the heater box seal properly from unheated air.
Have you checked that the thermostat is good? the gauge may say normal but the blue one could be running cold.
Blue after all is a colder colour Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #674999 1st Jan 2018 6:41pm
