Home > My Defender > Grafty's Td5 90 |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 |
Do they come with preinstalled hot air ??? If so You could make a fortune
30th Dec 2017 4:29pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4792 |
Not yet but the warm air that does make its way out will actually hit you rather than warming up the bulkhead 2002 90 Td5 Station Wagon
30th Dec 2017 4:54pm |
Warm air
That only happens when the wife's about |
30th Dec 2017 5:01pm |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 507 |
That looks fantastic! I like the idea of being able to choose either your feet or face as opposed to the fixed pieces which seem to try to split it between feet and face but ends up just guiding away from anywhere useful Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
30th Dec 2017 5:04pm |
Thanks, another unseen benefit is that when they're set at the correct rotation they blow onto the side window - possibly doubling up as side window demisters 2002 90 Td5 Station Wagon
30th Dec 2017 5:16pm |
Thanks lb73 2002 90 Td5 Station Wagon
30th Dec 2017 7:20pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5219 |
i wouldn't mind a pair of vents like that grafty once you have perfected the design Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
30th Dec 2017 7:44pm |
30th Dec 2017 8:02pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10844 |
That was quick grafty did you finally sort out the turning stiffness that we talked about ?
Looks good Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
30th Dec 2017 9:56pm |
Yeah got the rotational stiffness just about right I think 2002 90 Td5 Station Wagon
30th Dec 2017 10:05pm |
Thats good to hear Clayton.
30th Dec 2017 10:50pm |
Version 1.1 is printing as we speak with a bit of a dimension tweak 2002 90 Td5 Station Wagon
30th Dec 2017 11:00pm |
Nice looking forward to the dimension tweak pic Clayton.
30th Dec 2017 11:09pm |
Well here is a sneak preview, still on a low quality fast print but the tabs for the screws are thicker and slightly wider apart to line up with the holes in the dash. The nozzles are being printed over night
Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
30th Dec 2017 11:42pm |
