Home > Maintenance & Modifications > Which sound proofing? |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5836 |
Never seen one used in anger, but the video/description seems to show that the blanket actually drapes over the back of the engine, not fully covering the top. I think there might be a recommended max air temp, so summer here in the alps might require removal if a long drive or lots of hills are planned. But the rest of the year, and certainly winter, should be fine. I wonder if it will actually make it better in winter? Having said that, will add larger intercooler, hoses etc, in the future so will hopefully all aid heat management. Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
26th Sep 2017 7:35pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Out of interest does anyone know what sound proofing twisted use in their defenders?
2nd Oct 2017 12:18pm |
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 |
+1 Fatmat is what I installed too, and would definetley recommend. Made so much difference and the pricing isn't too bad. |
2nd Oct 2017 5:08pm |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 |
Silentcoat has done wonders for my 110. I've only done the bulkhead, front floor, battery box & a third of the roof but it's made a massive difference! You don't need to cover every inch, I've just dropped one on each panel and got loads of sheets left to use. I did use a heat gun which made it stick like the proverbial...
55mph on the M5 and I can now hear my music! |
13th Oct 2017 4:08pm |
Does it make a difference to the sound inside the cabin? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
14th Oct 2017 7:29am |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
By far the best under bonnet insulation I have used is described in this thread
http://www.defender2.net/forum/topic48682....insulation |
14th Oct 2017 10:23pm |
Thanks BM, same route I'm thinking of going, Monsieur Le Grenadier
15th Oct 2017 7:54am |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
After doing some 1200km over the weekend I was just searching soundproofing as well. A lot of these solutions seem to be helpful at speed up to 70km/h or so. I am really looking to lower it at higher speeds of 120km/h. (I've a 2.2).
The noise killer kits, are they any good at deadening noise at higher speeds? |
16th Oct 2017 9:58am |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
pffft I wish I could go 120 km/ph 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
16th Oct 2017 10:23am |
I suppose it depends on the level of insulation put in. I'll be hopefully doing the following. Silent coat on all metal skin surfaces including full foot box, plus I'll remove the floor plates and add under as well as over. High Density Foam sound barrier on inside of door cards, all floor surfaces, throughout footwells , inside seat boxes and twin layer on roof. Carpet throughout Rubber floor mats SC and Sound barrier on all bulkheads New alcantara roof lining (potentially packed out with acoustic wool. Engine bonnet insulation, double layer plus foam trim to seal with wing tops, as mentioned in post above. Bell housing blanket Engine blanket Upgraded door seals Door realignment New front window seals New front window clamps Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
16th Oct 2017 11:17am |
Taken mine all over Europe at 80is mph and all good as described in my post above, this was on a 2.2 110 and my previous 2.4 90
16th Oct 2017 5:11pm |
big ives Member Since: 24 Dec 2013 Location: Northern Ireland Posts: 125 |
Another vote for silent coat, just completed my 90 last weekend , reinstalled the carpet and test drove and I am impressed the noise has reduced
I also done my doors and they feel and sound so much more solid 2016 Discovery 4 1989 90 CSW V8 (fully rebuilt and running like a dream) 1996 defender tray back fully rebuilt/loaded for challenge events |
16th Oct 2017 9:52pm |
Is this a good deal? http://www.ebay.co.uk/itm/Silent-Coat-2mm-...1438.l2649
Can I cut the sheets to fit as needed or do they need to stay whole? 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
23rd Oct 2017 2:28pm |
i used 3mm
yes very easy to cut to suit i obviously cleaned the panels then i heated each floor panel or area with a heat gun, just a little heat and the silent coat pads stick better IMHO 2016 Discovery 4 1989 90 CSW V8 (fully rebuilt and running like a dream) 1996 defender tray back fully rebuilt/loaded for challenge events |
23rd Oct 2017 2:36pm |
