Home > Maintenance & Modifications > Which sound proofing?
Page 6 of 6 <123456
geostrategist
United Kingdom 2008 Defender 110 Puma 2.4 CSW Tonga Green
Is the closed cell foam that is placed on top of the dynamit/ silent coat a finished surface? Ie will it put up with the normal wear and tear of normal use, or does it need a final layer, such as carpet or rubber to top it off?
Post #773317 16th May 2019 5:19am
donmacn
I guess it has to depend on exactly what you get. The stuff I got is an effective noise reducer, but either needs to be somewhere where there will be no 'wear and tear' or would need covered.
I've put it on top of silentcoat inside my doors - only where I could install it relatively easily, and where is wasn't fouling the window mechanism. In this location I'd expect it to be fine by itself.
I have some left over, and when deciding where to use it, if it was in a more 'dynamic' location, it wuld need covered by matting or carpet. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #773322 16th May 2019 7:11am
Grenadier
In short, no. Certainly not anywhere where it has regular contact/abrasion from feet, hands, bodies, bags etc. Which really leaves almost no part of a Defender. It’s a foam, with inherent (or lack of) strength and resilience you’d expect. Cover it with carpet, mats or trim/linings. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #773326 16th May 2019 7:32am
geostrategist
Donmacn and Grenadier
Thanks, that’s what I suspected.
Post #773328 16th May 2019 7:44am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Just doing my 110 now. Silent Coat covered by 6mm closed cell foam and then on the rear passenger floor and the load area floor I've put 6mm plywood to protect the foam and take any point loads. Over this I'm doing rubber matting rather than carpet. All glued down with waterproof spray glue and the edges sealed with Tiger Seal to help stop water ingress.
For the back passenger area and load area I've used this rubber matting that is near identical to the profile of the land rover produced stuff:
https://www.amazon.co.uk/gp/product/B072Q4...&psc=1
On the front floors, I'm putting silent coat on the floors with a bead of Tiger seal between sheets to seal but no foam existing rubber matting should do the job. For the seat box I've got some 3mm closed cell for the sides as not a lot of space when doors close.
Hope that helps
Post #773332 16th May 2019 7:59am
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
probably been said, but on the seat box, the carpet sets do not allow for much under neath, i used a totally different product which is only 2mm thick and in places it was tight for the LRI carpet over the top, so if adding closed cell foam just check beforehand.
Post #773366 16th May 2019 1:47pm
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
That's interesting, I used an LRI carpet set for the rear of my 90 and it was huge and I had to trim off loads, and that was including 3mm silent coat and 6mm CCF. To that end I wouldn't touch their carpets again and for the front I have bought genuine ones
Post #773370 16th May 2019 2:27pm
Snowy90
I think, to be fair the rear can accommodate a thicker under layer, it was not so much the overall dimension as i had to trim around the perimeter but more where they had precut the seat box corners. I am pleased with the LRI carpet but it is thinner than others i have seen.
Post #773372 16th May 2019 2:41pm
theheffman
United Kingdom 2003 Defender 90 Td5 SW Cairns Blue
I know this is an old post, but hoping you can help.
I am going to apply the 2mm silent coat on my TD5 90 cab and then the 6mm foam on the roof.
My question is how to apply the carpet after the silent coat is stuck down. In my limited experience the carpets are glued down and getting the carpet off often damages the carpet. Do you mainly fir new carpet over the top of the silent coat ?
thanks
john
Post #808585 3rd Jan 2020 11:42am
Snowy90
Hi John,
My only experience is fitting new carpets and yes they were spray glued down, just a thought you may be able to ease the old carpets off with some thinners or the like working along the edge which may save some damage.
Then just replace the carpet and use a spray contact adhesive.
Post #808610 3rd Jan 2020 3:57pm
Page 6 of 6 <123456
