Home > Maintenance & Modifications > Which sound proofing?
Page 3 of 6 <123456>
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Oh great so the stuff doesn't leak out if you cut it in half?
That's going to make doing the front footwell allot easier 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #659167 23rd Oct 2017 2:59pm
Grenadier
I bought everything from Sound Deadening Shop direct, speaking to Colin. The price I was given for the bulk packs as a Def2 forum member were £67.92.
I also bought Isolator 6 ( large single sheet) @ 10.19
2 x Pro Barrier in 5m x 1m roll @169.99. (This was for é x 110SW and 1 x DCPU)
Very helpful, so I'd contact them direct for a best, Def2 price. Thumbs Up
PM following with contact email. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #659173 23rd Oct 2017 3:32pm
Kit
I've just shot them a message on facebook Grenadier Thumbs Up 1993 200 Tdi 90 CSW
Post #659178 23rd Oct 2017 4:07pm
Grenadier
At this rate you'll get it fitted before me. It's only been a year since it was delivered. Whistle Monsieur Le Grenadier
Post #659185 23rd Oct 2017 4:35pm
Kit
haha! well, im aiming for this weekend? Razz 1993 200 Tdi 90 CSW
Post #659189 23rd Oct 2017 5:01pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Think I'm going to order some silent coat tonight.
A pack of 5mm to do my bulkhead behind my front seats as my sub is mounted to it and it rattles like mad. All the left overs from this I'll use on the footwells and maybe rear wheel arches depending on whats left.
A pack of the 3mm for boot floor, seat box and everywhere I can stick it really.
Lastly some 6mm isolator closed cell foam to go on top.
Obviously buying it is one thing and fitting it is another but I'll try to remember to report back when I've done it.
Not bothering with the roof yet as I want a new headlining and I'll do that all together as one job
Post #681626 25th Jan 2018 5:00pm
Djcla
I'm looking at this to do the back of my SW and found some stuff on eBay that seems excellent value. No idea if it's any good but for the price looks worth a punt to me.
https://rover.ebay.com/rover/0/0/0?mpre=ht...2084102902
Post #683956 3rd Feb 2018 10:14pm
That stuff is primarily thermal insulation. It's probably an ok substitute for 6mm closed cell foam but doesn't do the same job as the dense products like Silentcoat. Darren
Post #684006 4th Feb 2018 9:17am
bankz5152
Should use both together for best performance.
Post #684009 4th Feb 2018 9:30am
Djcla
Ah ok, how does silent coat differ from a decent laminate underlay for instance? Like this for example apart from the sticky backing? Silent coat etc just seem a lot of Dosh.
https://www.diy.com/departments/duralay-3m...316_BQ.prd
Post #684010 4th Feb 2018 9:36am
Silentcoat and the like are a dense bitumen based material designed to reduce the resonance of panels. They work because of their mass. Foam based products are sound absorbers and reduce reflected noise. As bankz says, the two different types should be used together for the best results.
Silentcoat, etc generally doesn't need to cover every square inch of a panel to work, although it's often easier to do so. Foam, on the other hand, works on surface area and so should be edge to edge where practical.
The laminate flooring stuff again would substitute for closed cell foam but is probably less effective than the proper stuff for this application. Darren
Post #684036 4th Feb 2018 12:11pm
Djcla
Thank you, so if i went for 2mm silent coat in the back of 90 with carpet over top then rubber mat would that be a decent start, or should i get 3mm etc?
Post #684038 4th Feb 2018 12:21pm
Yeah, that's what I did and it's made a huge difference. That coupled with 6mm foam on the vertical surfaces above the wheel boxes, hard top sides and roof above the lining. I haven't done the front yet but roof, sides and rear tub have totally transformed it. Darren
Post #684041 4th Feb 2018 12:47pm
Djcla
Ah ok so some stuff like I found eBay that I linked earlier on sides / roof etc?
Post #684052 4th Feb 2018 2:18pm
Something like this should give you enough to do the roof and sides:
https://www.ebay.co.uk/itm/3m-Roll-Car-Sou...0005.m1851
So far, I've used one box of 40 sheets of Silent Coat to cover the rear tub (floor, wheel boxes and sides up to cappings), the inside of one door and isolated panels on the roof before the foam went over the top.
 Darren
Post #684111 4th Feb 2018 6:05pm
