Home > Maintenance & Modifications > Which sound proofing?
Page 2 of 6 <123456>
Grenadier
Never seen one used in anger, but the video/description seems to show that the blanket actually drapes over the back of the engine, not fully covering the top. I think there might be a recommended max air temp, so summer here in the alps might require removal if a long drive or lots of hills are planned. But the rest of the year, and certainly winter, should be fine. I wonder if it will actually make it better in winter? Having said that, will add larger intercooler, hoses etc, in the future so will hopefully all aid heat management. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #653022 26th Sep 2017 8:35pm
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
I have had one on my TD5 110 for a couple of summers and driven to Belarus both summers where it has been 35-40c with no I'll effects on heat dissipation . Thumbs Up
Post #653221 27th Sep 2017 7:29pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Out of interest does anyone know what sound proofing twisted use in their defenders?
Post #654333 2nd Oct 2017 1:18pm
Coatesyyy
bankz5152 wrote:
Try Fatmat instead, very similar to Dynamat but cheaper and the quality seems identical as does performance. Did both my 90 and 110 with it, no issues what so ever to report.
It sat in my 90 for 3 years and going on a year in my 110. Definitely makes a big difference
However its best when used with multiple layers of closed cell foam* where ever you can fit it really! Then a final layer of carpet/rubber trim on top.
*When sticking down use a high temp heavy duty spray glue, not the self adhesive foam, slight bit of heat and it comes away...
+1 Fatmat is what I installed too, and would definetley recommend. Made so much difference and the pricing isn't too bad.
Post #654388 2nd Oct 2017 6:08pm
Fatbaron
Silentcoat has done wonders for my 110. I've only done the bulkhead, front floor, battery box & a third of the roof but it's made a massive difference! You don't need to cover every inch, I've just dropped one on each panel and got loads of sheets left to use. I did use a heat gun which made it stick like the proverbial...
55mph on the M5 and I can now hear my music!
Post #657094 13th Oct 2017 5:08pm
Grenadier
Does it make a difference to the sound inside the cabin? Monsieur Le Grenadier
Post #657211 14th Oct 2017 8:29am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
By far the best under bonnet insulation I have used is described in this thread
http://www.defender2.net/forum/topic48682....insulation
Post #657330 14th Oct 2017 11:23pm
Grenadier
Thanks BM, same route I'm thinking of going, Thumbs Up Monsieur Le Grenadier
Post #657345 15th Oct 2017 8:54am
dantastic
After doing some 1200km over the weekend I was just searching soundproofing as well. A lot of these solutions seem to be helpful at speed up to 70km/h or so. I am really looking to lower it at higher speeds of 120km/h. (I've a 2.2).
The noise killer kits, are they any good at deadening noise at higher speeds?
Post #657553 16th Oct 2017 10:58am
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
pffft I wish I could go 120 km/ph Big Cry 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #657560 16th Oct 2017 11:23am
Grenadier
I suppose it depends on the level of insulation put in. I'll be hopefully doing the following.
Silent coat on all metal skin surfaces including full foot box, plus I'll remove the floor plates and add under as well as over.
High Density Foam sound barrier on inside of door cards, all floor surfaces, throughout footwells , inside seat boxes and twin layer on roof.
Carpet throughout
Rubber floor mats
SC and Sound barrier on all bulkheads
New alcantara roof lining (potentially packed out with acoustic wool.
Engine bonnet insulation, double layer plus foam trim to seal with wing tops, as mentioned in post above.
Bell housing blanket
Engine blanket
Upgraded door seals
Door realignment
New front window seals
New front window clamps Monsieur Le Grenadier
Post #657565 16th Oct 2017 12:17pm
bm52
Taken mine all over Europe at 80is mph and all good as described in my post above, this was on a 2.2 110 and my previous 2.4 90
Post #657646 16th Oct 2017 6:11pm
big ives
Another vote for silent coat, just completed my 90 last weekend , reinstalled the carpet and test drove and I am impressed the noise has reduced
I also done my doors and they feel and sound so much more solid 2016 Discovery 4
1989 90 CSW V8 (fully rebuilt and running like a dream)
1996 defender tray back fully rebuilt/loaded for challenge events
Post #657770 16th Oct 2017 10:52pm
Kit
Is this a good deal? http://www.ebay.co.uk/itm/Silent-Coat-2mm-...1438.l2649
Can I cut the sheets to fit as needed or do they need to stay whole? 1993 200 Tdi 90 CSW
Post #659163 23rd Oct 2017 3:28pm
big ives
i used 3mm
yes very easy to cut to suit
i obviously cleaned the panels then i heated each floor panel or area with a heat gun, just a little heat and the silent coat pads stick better IMHO 2016 Discovery 4
Post #659164 23rd Oct 2017 3:36pm
