Home > In Car Electronics > The definitive Defender ICE thread
Page 59 of 71 <123 ... 585960 ... 697071>
barbel jim
It's almost our own thread Steve Rolling with laughter
Post #593251 15th Jan 2017 4:18pm
Pretty much. Laughing
Busy fiddling about at the moment with lights instead. Off Topic TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #593256 15th Jan 2017 4:31pm
barbel jim
Due to the new wheel arch adapters, I'm having to remake the rear speaker pods, which begs the question, Do I swap the rears for 6" focals Whistle
Post #593261 15th Jan 2017 4:46pm
I'd have thought upgrades come naturally.
Bigger is always better, most of the time. Whistle TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #593263 15th Jan 2017 4:49pm
Well, sadly I have some bad news.
My Kenwood KVT729 HU has passed away after ten years of service.
It has not been working for some time correctly, I disassembled it and it looks like some of the PCB's have gone under.
This seemed to start with the removable faceplate, however, it's definitely terminal.
I cannot complain, for the time I have had it and has been in three vehicles.
It is now out of date anyway.
So being HU less at the moment I've bought a cheapy replacement I'm off to pick up today.
Quite looking forward to it, as even though the replacement is fairly cheap and basic im sure it'll sound better being much more up to date with new electronics.
This will suit me for the time being rather than going around with an empty dash slot.
At a later date I'm going to contemplate going 2DIN regardless of cost as this is where the industry is going.
I'm also looking to move away from Kenwood as a brand and look at the alternatives.
Anyone care to share how they feel about their make and model of 2DIN HU?
Very Happy TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #605223 27th Feb 2017 11:41am
reijnard
Netherlands 2002 Defender 110 2.5 TD CSW Barolo Black
jont wrote:
Managed to get a few more bits done today Very Happy
Spliced the tweeter wiring in to the loom...
Fitted the cage into the new dash frame...
Moved over the switches from the old silver XS dash...
All switches connected and fitted...
Tweeters in place...
Fired it up and all works Thumbs Up
Just the sub to wire up now - have fitted to back of the cubby box !
hello I'm new here and from holland.
i ordered a raptor double din frame for my defender.
but it don't fit.
i must cut a peace of the frame before i can place my pioneer double din.
you had the same problem?
thankss
Post #650281 14th Sep 2017 1:02pm
reijnard
Post #650283 14th Sep 2017 1:22pm
Coatesyyy
Some fantastic install ideas in here! Thumbs Up
Post #652609 25th Sep 2017 11:09am
bankz5152
reijnard wrote:
Buy a new din cage. They arnt all exactly the same size
Post #652635 25th Sep 2017 12:33pm
GrahamGParker
2015 Defender 110 Puma 2.2 USW Corris Grey
I have just fitted a MUD CUBBY BOX LOCKER the slide-able version. I have a Alpine sub fitted to the back of the cubby box as fitted by landcover as an upgrade when new. I need to extend the wires so that the sub slides with the cubby or extend the wires and fit in a completely different place.
Any advice going on this?
Also to make it easier I thought it would be better to get a male and female of this connector to use as the extension lead. But can't find anyone who sells them. I think its a Yesc Kaizen connector any ideas?
Post #652789 25th Sep 2017 8:49pm
bankz5152
Could always change the connector to one you want to use. If you can't find one just as easy to cut the connector off and extend the cables to where ever they need to go.
Heres what I did with mine, same sub just not from LR.
Image shows the underside of the Mud locker, the wiring is from the sub.
Post #652875 26th Sep 2017 9:44am
GrahamGParker
I think thats the way I will have to go!!
Just thought it would be easy to get a plug for an extension lead!!! But doesn't look like it is that easy
Post #652876 26th Sep 2017 9:50am
bankz5152
Fitted my new Raptor Dash and Double Din!
So far it has -
Twin 5v USB
Single 12v Socket
Single USB for memory sticks, music, video etc.. but also charges
3.5mm Aux
Bluetooth - Calls & Music
External Mic for Calls
HDMI & MHL
Spotify Link
DVD Player
Voltmeter
Reverse Camera (switches to video when in reverse)
Parking Sensors + Switch to turn off when off road
So many features! Got a few bits on order to get the full benefit from it such as DAB Aerial & Air Cast dongle (wireless screen mirroring on Android). Eventually TV will go in as you can get a decent tuner for around £50!
Tell you with all the extra wiring it only JUST fits! Very happy though!
Post #656045 9th Oct 2017 10:54am
UPDATE.
Haven't been on this thread for a long time, mainly due to having little reason to really.
Everything is fine my end, my Kenwood DVD HU finally went under late last year after nearly ten years use!
Not the end of the world as it was quite out of date anyway.
I'm probably going to go for that new Pioneer version at some point but at the cost, is a limiting factor so that maybe an if and when kind of thing.
For now I'm just running a mechless iPhone, iPod etc compatible JVC unit which was cheap at £40.
It'll do for the time being, and is surprisingly good for the price!
Sound is actually better than the KW, probably due to being so much more modern.
I'm intending to remove my current Kenwood speakers also, they have been good but there are much better on the market now but they are fully working and nit half bad.
I have plans to replace them, but will be 10cm swap but I won't be going up to 13cm.
I'm also intending to leave all factory wiring in situ, but rewire with ISO plugs so I can keep everything separate and revert back if I needed to.
I'm planning to Amp all four speakers, with Daisy chain input from my existing Amp for my sub RCA's to the new Amp.
This has master Amp control also.
Speaker grilles are also very trick, and suits my set up well.
All in, quite pricy though but might try and go for it Christmas + Would be imported from the USA so might be even longer.
Other than that, that's the only info you are getting.
I've also got other interior upgrades planned, relatively minor and not audio related though.
Mr. Green TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #660707 30th Oct 2017 8:32pm
Not sure if I'm talking to myself here or not but.... πŸ˜…
Has anyone fitted speakers on the door panels /cards? If so what size?
I think there are posts on this thread but 52 pages or so takes some going through. Laughing TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #668351 1st Dec 2017 11:48pm
