![]() | Home > In Car Electronics > The definitive Defender ICE thread |
I got some 50th door speaker rings off Ken which I will be fitting at some point, I think they are roughly 6" I'll be putting 3 way components in so needed the door speaker holes. Ray
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
Hi Steve,
Yes people have fitted in the door cards, but I'm pretty sure most if not all have used spacer rings. A defender door isn't really that suited as the seat box and window motor limits mounting positions.. In an ideal world you'd mount them mid dooor, but you'd be resting your knee on them. Most mount them in the bottom of the door by your feet, which depending on your use of defender works for some. https://www.defender2.net/gallery/albums/u...G_0037.JPG Lasalle make these http://www.lasalle-trim.co.uk/product/fron...using-pair if that helps ![]() |
The Focal K2 power crossover has an added option of setting the woofer to high or low position, playing around with this plus the + db foe the tweeter you can achieve a really full sound. For the bass gain of a 6" I dont think its of benefit to move into the doors. Interestingly though, I have the K2 powers in both, yet have each set up slightly different to achieve the same sound ?? Ray with his 3 way components will I think need the door card option, with the 4" cone and tweeter in the usual places.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20626 ![]() ![]() |
Finally got the time to go through all the pages on this thread at last, makes for interesting viewing and reading.
And thank-you also to Martin for reinstating some of the pics a certain photo sharing site removed. ![]() I'm planning on changing all my speakers present for another higher power set of 4" ones, Amp driven. Won't be going larger still on those... Keeping my Tweeters as they are, currently running just a cheap JVC HU at which does fine for now. (Not gong to embark on too much in one go!) And for its price is surprisingly good! I am seriously considering 6.25" in doors, and above rear door again Amped. I already have the speakers en route, one pair arrived the other day for the factory fit locations. I hoping to get the Amp shortly for these too. The 6.25" speakers I will need to look at afterwards, and the amp also due to cost. But I will be running three Amps in the end hopefully and the custom fit work especially the rear to do. The part that will slow me down will be the cost, which is near £1000 ![]() I think it's achievable, the speaker grilles look excellent and will custom paint them and all will match. When I'm done power should be around 2600w, and will add better mid and bass range again. Midrange is lacking just a little at the moment. Amps will have the EL wire surrounding also hopefully! Plus they have their own red "light pipe" design etc. The speakers, the 6.25" ones will also have some very special features, not just brilliant audio quality but visual and other benefits. Watch this space. ![]() ⛽️🛢️⚙️🧰💪 |
Over half way there with my plans..
Does anyone have any plans for theirs coming up? Probably when it's not -2.C though. ![]() ⛽️🛢️⚙️🧰💪 |
Custard1640 Member Since: 24 Nov 2017 Location: suffolk Posts: 6 ![]() ![]() |
This has transformed my TD5 110. Raptor dash was just £50 pioneer Apple car play head £350. Going to go win JL audio sub and new mid range speakers and tweeters.
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 282 ![]() ![]() |
Can anybody recommend a good plug and play replacement for the standard speakers and tweeters? I want to to keep original Alpine sub and headunit. I hear Rainbow are good...
The problem is your power source.
Do you have an Amp to drive what you want or relying on just the HU? If the latter, no problem but it limits wattage and output capablity a lot. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
I want to stick with the factory headunit. After much deliberation, I have decided to go with the Rainbow DL-C4.2 comp set for the front and Rainbow DL-X4 coaxials for the rear.
I am told they are plug and play but noticed the screw points differ from those on the factory-fitted speakers. Hopefully I will avoid having to drill new holes in the dashboard ![]() |
Ah yes that’s a common thing, any holes however are always covered so not much to worry about. 👍🏻
If your keeping the factory HU and wanted an amp you can use hi level in (speaker signal input) instead for many amps. (Check). Thus not requiring RCA inputs. OR there are in-line mini amps to can wire in, or if you have standard ISO DIN plugs more or less plug straight in. Just has a power feed to pick up and earth. All fitted behind the dash TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Here a photo of my setup
After some changes to the setup I’am very pleased with it. I have: Alpine ilx headunit. The CarPlay unit. Great Focals speakers in the original holes including tweeters in the front Alpine bass box mounted in a custom designed cubby box Small alpine amplifier (i’am not a audiofile) but you need play louder than the wind noise ![]() Front and rear camera. Rear camera will come on automatically when I shift in reverse. Front camera I have to tap on the head unit. The front camera I use at traffic lights. Since I have seat risers and i’am not too tiny I sat the whole time with my nose sticked to the windshield ![]() Click image to enlarge a defender from 1984 pretending to be a puma with a touch of Range Rover |
I just noticed that the comp speaker set comes with a 2-way crossover
You will need to fit the crossover to your new speakers as the standard speakers have one built in. Ray
