Home > My Defender > V8 90 Project |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Hi LRA, I know your concern and thanks for the advice, I was going to stick with standard bolts but these are the ones sold by YRM for the locations I am fitting, they are graded at A4-80 which matches the metric grade of 8.8. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
2nd Sep 2017 10:00pm |
Ah ha, fair enough! Darren
2nd Sep 2017 10:06pm |
3rd Sep 2017 7:08am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Coming along nicely Mash,
Keep up the good work 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
3rd Sep 2017 9:05am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10781 |
^^^ +1 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
3rd Sep 2017 9:33pm |
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 |
A lot of work but going to be a beauty that!
7th Sep 2017 12:23pm |
Okay after my little trip away I've managed to get a few hours in on the V8, it was rubbish weather so I decided to tackle the engine, I have spent some time cleaning it but I think it's a longer process yet
The gunk I have removed from the heads/rocker covers has been mental. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge It is amazing what a bit of Tlc can give you, a few more hours and it should be clean enough for some paint, then once built and fitted the test fire will no doubt coat the thing in oil and grime and the natural balance will be restored 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
9th Oct 2017 10:01pm |
Not too sure on the mileage I will have a rummage in the box marked x to confuse the enemy my speedo is hiding in it started as a strip/inspect then some funds freed up so I bought a few upgrades to fit, for now I'm not removing heads/pistons as the cylinders still show honing marks.
The black sludge I think Stems from a few missed services and the time it's been stood still, the sump oil was still fresh when I got it. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
10th Oct 2017 8:47am |
Nice work there Mash, a bit more tlc and it will look good as new 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
11th Oct 2017 10:02pm |
Okay a little bit of a boring update as pics of cavity waxing are far from exciting but with two litres pumped into the chassis I think I have covered most of it, my endoscope should be back in the uk tomorrow so I will have to check.
Click image to enlarge Click image to enlarge Click image to enlarge One things for sure this chassis should last me a long time even in Guernsey 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
15th Oct 2017 10:21pm |
Loving the workshop
16th Oct 2017 6:54am |
So do I but I only get to use it in the evening or weekend 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
16th Oct 2017 8:09am |
^^^ That is better than not at all 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
16th Oct 2017 6:53pm |
okennedy Member Since: 12 Sep 2017 Location: Roscommon Posts: 42 |
Another great thread!
16th Oct 2017 9:26pm |
