Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 43 of 81 <123 ... 424344 ... 798081>
mk1collector
Well, as my defender has been whistling at people for a week or two now I thought I'd better get it sorted so ordered in the bits and they arrived before the weekend.
As you can see when I stripped it the leak was on number 5
All studs out ready for new
And the one snapped offending stud removed
All new studs in
The difference between the old webbed manifold and the new de-webbed one
And all back together, thankfully with no more whistling Mr. Green
 Ray
My build thread
Post #633891 27th Jun 2017 3:10pm
AJC
Who de webbed your manifold for you?
Where the studs a pain in the ass to get out or did you manage ok?
I assume you pilot drilled the snapped one and used an extractor?
Good work
Post #634033 28th Jun 2017 7:48am
mk1collector
Hi, the manifold I bought from a seller on eBay' pre stressed and de-webbed, milled flat and painted with all the gaskets in the kit. The up rated wurth studs and copper nuts were also bought from eBay but a different seller. The studs came out pretty easy using the two nut trick (if you don't know how to do this look it up on YouTube, its really easy) and as you said the snapped stud was pilot drilled and removed with an extractor which was also not that bad of a job Thumbs Up Ray
My build thread
Post #634141 28th Jun 2017 3:04pm
AJC
Spot on, I've got some proper stud extractors at home, lot easier than the 2 nut jobby
I was just curious about the manifold in case mine decides to go
Post #634142 28th Jun 2017 3:09pm
Tiger
Right Ray, now I'm 110(less) I'm relying on you to keep this updated regularly, so I can keep up with the mods fix.
Keep up the good work.......we are watching Whistle Thumbs Up
Post #634144 28th Jun 2017 3:11pm
mk1collector
I found the manifold through a thread on here that someone had recommended so the chap seems to have been selling them for a while. His add says they are genuine Landrover ones too. Ray
My build thread
Post #634145 28th Jun 2017 3:13pm
mk1collector
Rolling with laughter well I should be finishing my rental refurb soon so I'm hoping to start getting a few jobs done that I've been planning for a while Thumbs Up Ray
My build thread
Post #634147 28th Jun 2017 3:15pm
mk1collector
Well the house refurb took a lot longer than expected and cost a lot more than expected Big Cry so for the time being I got the allisport intercooler welded up at a local shop as there was a massive split in it. Got it fitted today so we'll see if it holds up and next year I'll stick a bas hi flow one on. Hopefully a few bits getting done in the next couple of months though. Ray
My build thread
Post #643695 13th Aug 2017 7:48pm
L110CDL
Good to have you back Thumbs Up house refurb's always go of budget and time, but at least it's done now Wink 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #643745 13th Aug 2017 9:59pm
mk1collector
Thumbs Up cheers, it wouldn't be so bad if I was going to be living there Rolling with laughter Ray
My build thread
Post #643746 13th Aug 2017 10:05pm
L110CDL
Rolling with laughter Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #643760 13th Aug 2017 10:23pm
bankz5152
Good purchase, I've had the same one on my 110 for 6 - 7 months now with zero issues. Though I didnt risk removing the studs!
Post #643840 14th Aug 2017 11:40am
mk1collector
Yeah it seems to be working great, as for the studs I was a bit worried about swapping them but as one was snapped and I suspected another would snap if re-tightened I bit the bullet and went for it and to be honest it was a lot easier than I expected. Ray
My build thread
Post #643882 14th Aug 2017 3:14pm
mk1collector
My second row door hinges have started having lots of play lately so I ordered a new set that turned up today.
In primer
And all painted and clear coated
I'll leave them to harden for a couple of days before fitting them with the stainless bolts I bought from 4x4 overlander ages ago but this is all temporary until gore brings out a full 110 hinge kit.
Thanks for looking Thumbs Up Ray
My build thread
Post #644034 14th Aug 2017 10:24pm
L110CDL
Looking good there Ray Wink Whistle 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #644037 14th Aug 2017 10:35pm
