Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Well, as my defender has been whistling at people for a week or two now I thought I'd better get it sorted so ordered in the bits and they arrived before the weekend.
Click image to enlarge As you can see when I stripped it the leak was on number 5 Click image to enlarge All studs out ready for new Click image to enlarge And the one snapped offending stud removed Click image to enlarge All new studs in Click image to enlarge The difference between the old webbed manifold and the new de-webbed one Click image to enlarge And all back together, thankfully with no more whistling Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
27th Jun 2017 3:10pm |
Hi, the manifold I bought from a seller on eBay' pre stressed and de-webbed, milled flat and painted with all the gaskets in the kit. The up rated wurth studs and copper nuts were also bought from eBay but a different seller. The studs came out pretty easy using the two nut trick (if you don't know how to do this look it up on YouTube, its really easy) and as you said the snapped stud was pilot drilled and removed with an extractor which was also not that bad of a job Ray
28th Jun 2017 3:04pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1364 |
Spot on, I've got some proper stud extractors at home, lot easier than the 2 nut jobby
I was just curious about the manifold in case mine decides to go |
28th Jun 2017 3:09pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Right Ray, now I'm 110(less) I'm relying on you to keep this updated regularly, so I can keep up with the mods fix.
Keep up the good work.......we are watching |
28th Jun 2017 3:11pm |
I found the manifold through a thread on here that someone had recommended so the chap seems to have been selling them for a while. His add says they are genuine Landrover ones too. Ray
28th Jun 2017 3:13pm |
well I should be finishing my rental refurb soon so I'm hoping to start getting a few jobs done that I've been planning for a while Ray My build thread http://www.defender2.net/forum/topic17615.html |
28th Jun 2017 3:15pm |
Well the house refurb took a lot longer than expected and cost a lot more than expected so for the time being I got the allisport intercooler welded up at a local shop as there was a massive split in it. Got it fitted today so we'll see if it holds up and next year I'll stick a bas hi flow one on. Hopefully a few bits getting done in the next couple of months though. Ray
13th Aug 2017 7:48pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10817 |
Good to have you back house refurb's always go of budget and time, but at least it's done now 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
13th Aug 2017 9:59pm |
cheers, it wouldn't be so bad if I was going to be living there Ray
13th Aug 2017 10:05pm |
Keeper. Clayton. |
13th Aug 2017 10:23pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Good purchase, I've had the same one on my 110 for 6 - 7 months now with zero issues. Though I didnt risk removing the studs! |
14th Aug 2017 11:40am |
Yeah it seems to be working great, as for the studs I was a bit worried about swapping them but as one was snapped and I suspected another would snap if re-tightened I bit the bullet and went for it and to be honest it was a lot easier than I expected. Ray
14th Aug 2017 3:14pm |
My second row door hinges have started having lots of play lately so I ordered a new set that turned up today.
In primer Click image to enlarge And all painted and clear coated Click image to enlarge I'll leave them to harden for a couple of days before fitting them with the stainless bolts I bought from 4x4 overlander ages ago but this is all temporary until gore brings out a full 110 hinge kit. Thanks for looking Ray My build thread http://www.defender2.net/forum/topic17615.html |
14th Aug 2017 10:24pm |
Looking good there Ray 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
14th Aug 2017 10:35pm |
