![]() | Home > Puma (Tdci) > who does and who doesn't use 1st gear? |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
when just driving round with out a trailer on typical A and B roads do you use 1st when pulling away from standstill ie onto an island / away from traffic lights. 1st gear is sometimes referred to as a towing gear which makes me think not?
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
I do all the time towing or not Mike
dave's 110 Member Since: 11 Jun 2008 Location: Norfolk Posts: 45 ![]() ![]() ![]() |
Me to only use 2dn to pull away if its a down hill start
Dave |
amatex Member Since: 01 Oct 2008 Location: Sussex Posts: 5 ![]() ![]() ![]() |
I use 2nd for flat and downhill pull a ways, I find 1st too low most of the time especially if i need to get out quick like at the bottom of our lane. 1st all the time with a trailer.
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 ![]() ![]() ![]() |
1st only with trailer or on hill start for me its too low and not needed.
2nd for daily use, flat or slightly inclined, i find it much smoother. DEFENDER XS CSW 08 TONGA GREEN |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
I tried this to overcome the appauling 1st to 2nd shift, but found I needed to slightly slip the clutch (not my prefered practice). What about the rest of you, any comments?
Bosun |
I find that to only slightly. but don't lick it as i'v already had
one clutch ![]() |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 ![]() ![]() ![]() |
1st when it needs it, otherwise 2nd.
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
I use first unless i'm setting off down a steep hill. I got sick of riding the clutch in second when setting off. 130 crew cab
98 V8 Disco |
Stephan Member Since: 13 Nov 2008 Location: Windhoek Posts: 12 ![]() ![]() ![]() |
Use 1st all the time due to the added weight of gears and kit on the 130. Stephan
Meiring II - 130 Puma 2008 Meiring I - 110 200TDI 1989/1991 |
Bundubasher Member Since: 25 Sep 2008 Location: Sandton Posts: 34 ![]() ![]() ![]() |
I use 1st gear all the time.
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I tend to use first most of the time.
If I need to get away fast (across a busy roundabout) then I use 2nd. First is great for catching out people that drive the Puma for the first time ![]() |
I use mostly 1st but like others have said to get onto a busy and fast roundabout it has to be 2nd.
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Mostly I use 1st gear, 2nd very seldom.
Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
