![]() | Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4794 ![]() ![]() ![]() |
They were. Although these are off a puma
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
The engine, chassis, axles and seatbox forwards is still original
Is putting your defender on the ramp to grease the prop shafts considered excessive use?
![]() Usually do it on the floor but thought "why not?" ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I'd wash it on the ramp too, no bending down!
![]() ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Grafty got the drl light stemp wired up till tomorrow
![]() Click image to enlarge ![]() Click image to enlarge 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Look better in person doesn't photo to well 2008 110 2.4 XS Utility (Hagrid)
Looks good! Very bright
Well yesterday I had a very stark reminder. Change your wheel bearings in pairs!
On the way to the Defender Day at Pentille Castle ( got it this time Clayton ![]() This is the result (skip to 3 minutes in) https://drive.google.com/file/d/0BymT3xBHs...p=drivesdk No warning at all - If this had happened a couple of seconds later I would have been toast ![]() Thanks again to Clayton for the lift home ![]() ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Well I have started to strip the O/S front. Looking like a new stub axle is required
![]() ![]() Click image to enlarge ![]() Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
It is amazing that it gave no warning and no noise before hand as it looks pretty dry. Although I suppose the heat could have burnt off and remaining grease
Time too check three more hubs
Well I changed the N/S a couple of weeks ago and checked the other 3 then. There was no indication of a problem when I checked which is the worrying part
![]() I will remove all the hubs and re grease and internally inspect them all this weekend ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5224 ![]() ![]() |
![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
