Home > Maintenance & Modifications > Bloomslang loom is it needed with Crystal headlights & B |
I think what Steve is trying to say is that the positions of pins 85 and 86 on his diode equipped relay are the opposite way around to a standard relay, hence he's had to swap the wires in the plug on the new loom?
Having said that, looking these two images, it would appear that it's pins 30 and 86 that are swapped. Standard relay: Click image to enlarge Diode-equipped relay, albeit a 30amp version: Click image to enlarge You're unlikely to notice any difference in operation though. Diode-equipped relays slow down the energising of the coil by a few milliseconds to prevent voltage spikes damaging sensitive electronics, but that doesn't really apply to spot lights. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
10th Feb 2017 8:46am |
pme Member Since: 06 Jan 2016 Location: cambridge and mainly ariege Posts: 49 |
I fitted a boomslang from paddock about 5 months ago, on an 07 plate puma. Fuse holder in the battery box. Had a funny recently where the headlights would not give main beam. Dug around, fuse holder had melted, "left hand " relay was also running hot. Main power lead to the fuseholder is sleeved in red, that was also running very warm, under the sleeve the cable looks big but if you strip it back its very fine. Replaced the holder and also the main feed from the batter, the wire is really not up to the job, more like a speaker wire. The wire to the front relays from the fuse holder seems much bigger in cross section. Maybe I was just unlucky and got a bad one!
Have a look at yours and see if the fuseholder is ok. rgds |
3rd Mar 2017 4:33pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20359 |
What was the fuse rating pme?
Was there any printing on fuse holder as to its current capacity? I'm happy with my Land Reziger loom, and if it wasn't available I'd have made my own loom. IIRC the Land Reziger loom is fused at 30A (twin feeds for main & dipped) which gives a good allowance for capacity but protection for wiring. The other trigger feeds etc are of course protected as standard fusebox rating. The Boomslang loom I'm not a fan of personally and the fuse holder mekting is a fire risk, either the holder is not rated to take the current or the fuse is rated too close to the current draw load causing it to overheat but not blow. I think there should be at least a good 5A difference rating on these above actual load, to factor in various variables, voltage spikes, inrush currents etc. Typically fuse rating is around 1/4 more than the current load, and is to protect the cable so the cable needs to be rated above the capacity of the fuse. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
3rd Mar 2017 5:16pm |
the fuse supplied was a 40Amp, no markings on the holder, I'll try and put some pics up on sunday from home, my satellite internet here cant cope
the cable from the battery to the fuse holder is less than 1mm in diameter! The solder tinning on the fuse holder has gone and it looks like copper underneath |
3rd Mar 2017 6:00pm |
Click image to enlarge the main battery cable copper is less than 1mm diameter, the crimp looks a bit rubbish as well Click image to enlarge Click image to enlarge Click image to enlarge |
5th Mar 2017 11:17am |
That is the exact type for fuse holder I had the same with too on my old spotlight feed.
I don't like the fact the input and output exit is in the same proximity either. With heat the insulation could melt touching the two feeds together bypassing the fuse altogether. If this was the case it'd definitely lead to fire. I now use fuse holders with horizontal exit and input feeds, and typically Durite if I can for good quality. The Land Reziger loom ones are good and also splashproof too. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 Last edited by custom90 on 13th Mar 2017 1:54pm. Edited 1 time in total |
5th Mar 2017 12:04pm |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 214 |
I had exactly the same issues with a boomslang loom, it completely melted the fuse and holder leading to an interesting drive one night... 1990 Defender 110 200TDI Camper - now converted to Td5 power
13th Mar 2017 12:55pm |
Fos_landy Member Since: 16 Nov 2016 Location: Devon Posts: 39 |
Hi all, just had the LED light kit and Crystal headlamps delivered from LRISolutions - all well and good, however trying to fit the headlamps, the lamps rotate - seems my assembly is missing a part (not plug and play...).
The crystal lamps are Wipac and the existing assembly is Wipac part 1050743 (presume the original part). Has anyone else had this issue? Thinking a simple fix is a full new WIPAC assembly - possibly: http://www.paddockspares.com/s5400-headlam...crews.html Currently sat blindly outside the garage looking very sorry for itself, so any help would be much appreciated Defender 90 Puma 2.4 |
4th May 2017 11:16am |
I tried to fit my Landreiziger loom today but failed due to a faulty relay, I needed to split the relay from the loom and ended up pulling the innards out of the dual case on both sides causing damage to innards, it appears that the plastic has not fused all round.so I'm having to replace the relays.
Now old age has crept up on me and I'm struggling to remember my knowledge of replays so have been searching and found that the relay supplied is a type B Photos below. Which may explain why Custonsteve had to swap the cables on his new relays or not , I think I have confused myself after eight hours of trying to find replacements. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
26th Jun 2017 8:10pm |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 |
Gents - apologies for reviving an old thread, but probably the logical location to post rather than starting a new thread.
My 110 had a Boomslang harness fitted when I changed the headlights, and added some AUX lights. Unfortunately I did not do the installation. Whilst the workmanship is good, none of wiring/fuses/relays have been labelled. Its a bit of a pain because in addition to the lights, the vehicle was fitted with a dual battery system, an additional fuse box, and several "consumers" such as camping and rock lights, compressor, etc... It means that for a non-electrical person such as me, diagnosing any problems is complex, as I do not follow the logic with which the installation was done. So - the problem at hand: The dip-beams on both headlights have stopped working, whilst high beam continues to work (flash and "always-on"). I plan to work through the probable causes: --> Main fuse on the boomslang haness > bulbs > relays on the harness > on/off switch in cabin. The problem is that as I did not do the installation, I am not quite sure where the relays and fuse have been located. So, the question(s) I have are: 1. Can anyone say where along the loom (working backwards from the headlights) are these located? Is there an obvious location where they would be installed? I have a bank on 5 relays on the passenger side wing (LHD vehicle), but these seem to be for the AUX lights. 2. Does anyone have a wiring diagram of the harness? I checked the website (http://redbison.nl), but it seems to not be working properly, and can's access the "Manuals" section. Many thanks for any inputs! |
24th Sep 2018 10:08am |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
This is the wiring diagram of " Gegio " : https://defendertricks.com/2012/03/01/solu...che-fonde/ Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
24th Sep 2018 2:10pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
My boomslang loom only has around 40cm of cable to connect to the original light circuit, and the "new" headlight connector. I would look next to the air filter, or the washer bottle depending which side they installed... Most seem to install the relays next to the washer bottle (nearside) apparently. You should be able to follow the thick wires back from the LH headlight this may help Click image to enlarge Maybe check the in-line fuse as well (seen in pic just below the relays), as one fuse will be for full beam, and one for dip... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
24th Sep 2018 2:16pm |
Thanks for all the feedback - very useful!
So I found the two relays - hidden behind the passenger side headlight - which needed to be removed to access them. A bit of a mindless location in my view, not least because they get some water. They didn't look great, but surprisingly they both worked when tested (at least the electro-magnetic coil). The hunt continues for the fuse(s). Click image to enlarge |
25th Sep 2018 11:05am |
@MartinK - Is that a Red Bison Boomslang harness? Its not the same as mine - this looks like a cleverer system which uses the original loom as a trigger for the relays, whilst getting the power from the alternator. My harness (if I recall) essentially replaces the existing one.
Does anyone have a copy of the manual / installation instructions? Or even the e-mail of Red Bison? |
25th Sep 2018 11:11am |
