Home > Maintenance & Modifications > Bloomslang loom is it needed with Crystal headlights & B
Page 1 of 6 123456>
Stacey007
Hello
Just about to order these Wipac Crystal lights,
http://www.paddockspares.com/rhd-crystal-h...r-w-o.html
Then I search a few posts about the wiring loom being upgraded using bloomslang kit
http://www.paddockspares.com/boomslang-per...-loom.html
Now, I really don't do electrics and when something says plug and play it generally isn't and I would probably end up switching my lights on with the wipers going and the horn beeping Smile Smile
Do I Need this loom? I will be fitting slightly better H4 bulbs with the wipacs... I don't fancy taking the car apart and not being able to fit this wiring kit...
What do people think can I keep the loom as it is (please) Thumbs Up (its not to save money... its to save me blowing something up)
Thanks
Post #563312 12th Sep 2016 10:17am
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
AFAIK the kit is just to give you a better voltage and current path up to the headlights. As is, you have a lot of resistance in your wiring going to the headlights - through the switches and possibly not great joints in your wiring etc. The kit gives you a more direct electrical path so you don't have as much voltage loss. If your new bulbs are the same wattage as your old ones then you can use your existing wiring, but to get a better light output you should use the kit. You're spending the money to see the road better, may as well go the whole hog.
Post #563316 12th Sep 2016 10:35am
VeeTee
Netherlands
As is written many times here, it is not the question if, but when the headlight switch will burn out. The construction of the switch is so that too much current is flowing through the contact points in the switch, these contact point become hot and the plastic part which holds the contacts will melt a bit and thus give room for loose contacts.
By upgrading with the Boomslang, Landreiziger or similar loom, the current through the switch is now only a fraction of the original current and now only needed to activate the relays. The larger current for the bulbs go through the relays.
Your switch will not burn out, there will arrive more volts at the bulbs, and the light output will be much better.
So, guess what my advice would be... Rolling with laughter Thumbs Up Cheers, Vincent
MySite
Post #563363 12th Sep 2016 2:50pm
Clive
Just to add to the above - it's entirely irrelevant which 55W H4 bulbs you fit with the crystal headlights, extra bright or extra dim, the current consumption of the bulbs and hence power through the switch will be the same, you will still end up with (relatively) dim lights and a fair possibility of the switch failing - unless you add the external relays/loom.
Post #563394 12th Sep 2016 5:12pm
YOLO110
Australia
Interested in this thread as well...
And the OP's question, Is the boom loom a true 'plug and play'? YOLO... You Only Live Once...
Post #563529 12th Sep 2016 10:36pm
ericvv
Dutch Landreiziger loom is plug 'n play. Well documented on here (do a little search), never read a bad comment about it on this forum. I have it installed for several years now, first with LEDs, later with my WIPAC Cristals again, just works great. And after 8 years, remain on my original switch. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #563535 13th Sep 2016 3:54am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Off topic..
Eric - what type of LED did you have beforehand and what was the reason for returning to Wipac Crystals please?
Thanks.
Post #563539 13th Sep 2016 4:56am
YOLO110
Australia
I think he just saw the light! Laughing YOLO... You Only Live Once...
Post #563549 13th Sep 2016 6:03am
Cupboard
The Boomslang loom isn't hard to fit and is a suitable first electrical project.
Run some cables in, attach to battery, attach to a decent grounding point, plug old headlight socket in to control plug for relays, plug headlamps in to new sockets, away you go.
You need some cable ties, an hour or two and to not mind rooting round underneath your Defender to get the wiring in. If you get in a muddle then you can always stop half way and use the old wiring until you get some help.
Post #563568 13th Sep 2016 8:55am
Stacey007
Post #563595 13th Sep 2016 10:57am
Stacey007
^ JUst looked at both and the paddock spares one does suggest
" With English and Dutch manual and installation guide "
So I'm thinking its the same?
Post #563599 13th Sep 2016 11:01am
VeeTee
Netherlands
^ In function they are the same, but different brands. I think Martin at Landreiziger is happy to supply an Installation Guide in English if you mail and ask him. They are both plug and play, not only in theory but also in practice. Thumbs Up Cheers, Vincent
MySite
Post #563632 13th Sep 2016 1:29pm
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
I'm quite tempted by the combination of Boomslang loom and:
LRI-Solutions wrote:
13pc Full LED light kit, crystal headlights, Xenon bulbs and stainless bezels-Forum: £215 (Website Price: £234, Ebay Price: £249.60)
Would be interested to know your thoughts once you've got the loom and Crystals fitted (if you go down that route). Would be a lot more affordable than the sealed LED headlight units and LED sidelights etc I was looking at. Keith
Post #563634 13th Sep 2016 1:32pm
Stacey007
^ There is so much choice...
I never thought it would be so hard to choose lights Smile
Wipac, RDX, NAS, led, crystal, plinths / without plinths..., / coloured / clear / smoked
aarrgghhh
I think I will order the Crystals and chance these as job one then see what I'm up to with the rest..
Post #563635 13th Sep 2016 1:59pm
VeeTee
Netherlands
I have the Clear Crystal headlights with Philips Extreme Vison bulbs (with relay loom), and RDX LED sidelights, indicators (+ RDX relay), rear/brake lights.
Very pleased with the performance. Thumbs Up Cheers, Vincent
MySite
Post #563646 13th Sep 2016 2:53pm
Page 1 of 6 123456>
