Home > Td5 > new fuel pump,cleand out harness now running s**t...help
Page 5 of 6 <123456>
lozza
pump is good and truck was running perfectly before pump went down in one trip without any sign until that day so am convinced its fuel issue somehow
Post #588498 29th Dec 2016 6:35pm
dorsetsmith
make your self a fuel line test hose out of clear plastic tube with 7.89mm quick release connector one male one female so that you check for air leak in fuel system you will be able to see air bubbles
Post #588593 29th Dec 2016 10:08pm
lozza
ok good idea that will tell me if the air valve is working,where do i get the connectors
Post #588607 30th Dec 2016 5:57am
dorsetsmith
have been trying to find my suppler but closed until 3 th jan 2017
7506QE2 Male end place 7.89mm / 7506QG5 female 7.89mm straight Gap Automotive
Post #588726 30th Dec 2016 5:24pm
01rwilkinson
England 2001 Defender 90 Td5 HT Rutland Red
Check for diesel in sump oil could be injector seals. .
Also check expansion tank not sure if you can get it sniff tested but check water level ,sounds
Like it might be faulty head gasket.good look.
Post #589345 1st Jan 2017 11:47pm
lozza
oil is good as is water,just gonna order a hawkeye and go on from there
if it ever happens i'll post up when fixed
loz
Post #589480 2nd Jan 2017 5:36pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
In Defender TD5 there are two "imobilizers" - in the 10AS unit - it blocks the starter relay and so if it is active, the starter will not turn. Second is in the TD5 engine ECU - this ECU must be paired with 10AS. In case of a problem with not-paired engine ECU and 10AS ECU the starter will turn engine, but engine ECU will not open injectors. To check these you need Nanocom or something similar. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #589646 3rd Jan 2017 7:21am
lozza
ordered hawkeye today ...the next step on the voyage of defendery !!!
Post #589891 3rd Jan 2017 9:04pm
lozza
ok latest,no faults on the diagnostic at m smiths indi,blown alll fuel lines out ,replaced air valve,fuel pressure switch,re cleaned and re fitted the injector harness,cleaned ecu end,was told by mechanic crank sensor eather works or not truck starts after a good time spinning up,kinda runs on lumpy3 -4 cilender clouds of white smoke,pressing the throttle it eventually revs up to max and kind of clears itself then ticks over like normal,press throttle a good way down before it revs,like a massive flat spot on a carbed engine,it will drive but its as flat as a big bag of flat things,
can someone tell me or point me to what the pressure readings on the hawkeye should be please or better still tell me WTF is wrong with it
loz
Post #591181 8th Jan 2017 7:26am
dorsetsmith
the pressure readings are under live reading
Clouds of white smoke
1. white smoke unbent fuel, it will have strong smell diesel
2. white smoke water in the combustion chamber
Post #591191 8th Jan 2017 8:48am
grafty99
Have you replaced the injector seals? I would also replace the injector loom rather than just clean it Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #591193 8th Jan 2017 8:50am
grafty99
Ignore that, I see you replaced the loom. Definitely look at replacing the injector seals though, reading through the thread it seems to be the only unexplored avenue Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #591196 8th Jan 2017 8:54am
lozza
fair comment but the oil is good
Post #591208 8th Jan 2017 9:49am
dorsetsmith
have had problem with the fuel connector suppler, on eBay all listing are from china with long lead time Exclamation
Post #591210 8th Jan 2017 10:07am
dorsetsmith
With the hawkeye you can fire the injectors with the engine not run so you test wiring and coil to each one
Post #591213 8th Jan 2017 10:13am
