![]() | Home > Tdi > 200Tdi Race engine - Weak points and limitations |
Boost Member Since: 17 Oct 2014 Location: Gloucestershire Posts: 203 ![]() ![]() ![]() |
I'd be up for that, maybe we could see if more people would be interested.
Have you got Quaife LSD's front and rear or was that someone else? Any other drivetrain upgrades, will you be using a paddle clutch for example? I'm thinking my 'heavy duty' Valeo clutch is going to take a hammering if I go much beyond 18psi and install the water/meth and nitrous. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10891 ![]() ![]() |
Agree This is a great thread, always on the edge of my seat when reading your Q & A
![]() I'm hooked ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 ![]() ![]() ![]() |
Uprated pistons sounds interesting
![]() http://www.totaloffroad.co.uk/vehicles/spe...e-changes/ This one I'll try get some prices for a set or 2. Yeah I have quaife rear. Ashcroft atb front and centre. And a hd ceramic paddle clutch. |
This was the one!
http://www.totaloffroad.co.uk/vehicles/spe...nd-goings/ "The first of the bits was a Range Rover chassis and the next bit was that 200Tdi engine. But, again, not any old engine. He acquired a Bowler engine with no intercooler, which is reckoned to produce nearly 180bhp. This went into the 100-inch chassis, mated to an R380 gearbox and a Discovery transfer case. All this was done in a couple of days." "The chassis was simply clean and stock, and that Bowler engine was an ex-race unit with uprated pistons and rings, crank and head gasket, plus a reworked injector pump. Power, he’s been told, could go up from 180bhp to 230bhp if he adds an intercooler and hybrid turbo. Tasty." ![]() |
I need these uprated pistons and rings!
Make your own, ceramic coat DIY style
![]() Will you be lightening the flywheel? |
I think you need them Matt as well
Pistons are being professionally coated along with the manifold.
No. Lightening seriously reduces the low end torque which I don't want to sacrifice. |
Excellent!
![]() ![]() Your engine will make mine look like a knackered Briggs and Stratton once it's finished!! Don't blame you though, why not? ![]() |
Yeah I looked at zircotec
![]() Haha. Well I want it to last a long time so anything I can do now to increase reliability....or power ![]() |
Merry Christmas everyone
![]() I think fully synthetic oil promotes leaks ![]() |
Perhaps switch to semi
Merry Christmas to you
I've never heard of that Bowler engine outside of the article, bet they're hens teeth!
![]() Turns out the cause of oil leaking may be more to do with a loose oil return line rather than fully synthetic oil ![]() |
