Home > Tdi > 200Tdi Race engine - Weak points and limitations
Page 2 of 15 <123 ... 131415>
Boost
United Kingdom 1986 Defender 90 200 Tdi SW Arles Blue
Hi mate, the return line coming off the turbo, once in place, is lower than the return union on the block. Doesn't look ideal for a gravity return as the line was swept back up to the block from the turbo when we fitted it, pretty annoying!
Hang 5 for those pics Thumbs Up
Post #584249 11th Dec 2016 8:39pm
L110CDL
Sorry to but in, but i'm following this thread with great interest as its great what you are doing with the engines and you know what your talking about, really great Bow down Clayton.
Keeper.
Post #584273 11th Dec 2016 9:21pm
Boost
As promised, some more photos!
Collection of cr@p
Thumbs Up
Post #584598 12th Dec 2016 9:08pm
Boost
Oops double post
Post #584600 12th Dec 2016 9:11pm
jst
have you checked the required air flow that turbo would need and matched it to the filter pipework, only that, and its probably the photo, that looks kinda small.
the tgv needs a min 3" for the c/s area to match required flow. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #584606 12th Dec 2016 9:24pm
Boost
Hi jst do you mean the diameter of the compressor inlet (or whatever it's called)? or the actual pipework diameter leading to the turbo?
Post #584615 12th Dec 2016 9:34pm
Boost
The purple pipe in that photo is 3" with a comically large K&N if that's what you mean?
Cheers Fred
Edit: Just guessed c/s stands for cross-sectional area Thumbs Up
Post #584632 12th Dec 2016 10:07pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
Glad to see you're making progress with this! At a much faster rate than what I am Rolling with laughter
Yes jst is talking about the c/s of the pipe from the filter. I agree on the picture it does look a bit small maybe because of the length of it. But 3" should be sufficient.
Will you be using 3" from the turbo to intercooler and intake or the standard 2" ones?
Also you might want to think about where the intake will be getting a cold air feed from, having the filter just lingering in the engine bay would not be as good as it being a real cold air feed not warmed by the engine.
Post #584664 13th Dec 2016 6:15am
Boost
Hi, yeah it's coming along Cool
I'm sticking with the 2" intercooler pipe diameter as not sure if there's anything to gain going bigger, correct me if I'm wrong though! I was thinking of routing the intake into the inner wing behind the headlight for a cold air feed, maybe drilling some holes under the plastic light surround for the full Mad Max effect Thumbs Up.
Matt are you going with a kit for your Variable Geometry setup? (sorry if you've mentioned it earlier)
Pic: Clearance with the stock oil return line - with the new turbo, its return is lower than the fitting on the block.
Post #584835 13th Dec 2016 6:03pm
Defendermatt
Ideally I would like to open the pipe work up a bit to 2.5 inch maybe. But going from 2.5 or 3 inches then closing down to 2 inches at the intake and IC ports will not be good for flow.
Like the sound of taking a hole saw to the front of the wing! Twisted Evil
Yes I will be having a kit. Not sure which yet and I'm a way off making the decision of what route to take yet.
Post #584909 13th Dec 2016 9:56pm
Boost
I think you're right Crying or Very sad , the cooler in/outlets are 3" and i'll be using 2" piping. Plus a load of it's just turned up in the post today, Cock!
I had a harebrained idea to cut the front of the intake manifold (where a coupler slides on to accept the boost pipe) thus enlarging the intake to 2.5"... Along with a 2"-2.5" coupler on the compressor outlet...
Damn it Rolling with laughter
Post #584915 13th Dec 2016 10:18pm
Boost
On second thoughts, surely the difference in lag between 2" and 2.5" intercooler piping is negligible, especially as the compressor outlet on the turbo is 2"?
Also I've got a GReddy boost controller I've used with the stock turbo that can be used to switch between low boost (10-14psi) and high-boost (15-30psi??? Shocked Twisted Evil )
Jokes aside what do people reckon a realistic safe boost is, for a burst of power for example? 20psi?
All good fun in a 30 year old crate! Thumbs Up
Post #584922 13th Dec 2016 11:31pm
Defendermatt
Yes any bigger pipes would not suit the fact that the IC and inlets are 2" still.
what intercooler are you going to use?
I have run 20psi (1.5bar) on a challenge truck all day long.
I have spoken with an Italian guy about a bi-turbo system he has built for the tdi and he said that runs 28psi on stock internals Shocked
Post #584934 14th Dec 2016 6:54am
Boost
The intercooler I'm using is a big universal one with 3" in/outlets
Post #584982 14th Dec 2016 12:11pm
Defendermatt
Looking good.
Are the outlets on the same side?
Post #584986 14th Dec 2016 12:22pm
