Home > My Defender > Grafty's Td5 90
Page 3 of 124 <123 4 ... 122123124>
AJC
Very nice 90
Post #581505 30th Nov 2016 7:16am
grafty99
Thank you AJC Very Happy 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #581515 30th Nov 2016 8:07am
grafty99
It's arrived Mr. Green
Going to try and fit today and get pictures of the stalks too as promised Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #581912 1st Dec 2016 11:57am
grafty99
Got the rev counter fitted this afternoon. Looks lovely Cool
I wanted the temperature gauge to stay where it was and move the fuel gauge to where the clock was.
Most of the online guides just move the temperature and fuel gauge one place to the right but I felt that engine temperature was more important than fuel level and needed to be more directly in line of sight. This required a couple of wires to be extended but easy nonetheless.
So here it is. I also changed the lamp to led to go with the rest of the gauges
Also as promised better photos of the stalks, please excuse the dirty floor mats - it is winter Embarassed
And finally whilst I was there I wired in the cruise control light that I did, I re made the warning light panel to include front fog and cruise warning lights. Just need to change the colour of the leds to green.
1990 Vogue SE
Post #581993 1st Dec 2016 7:35pm
L110CDL
Very nice there grafty99 Thumbs Up Clayton.
Keeper.
Post #582020 1st Dec 2016 9:10pm
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
funny enough i was only thinking yesterday about the old switches in the meastro/montego range and whether they would fit! they are the same as the RR ones shown. V8 90...WIP
Post #582024 1st Dec 2016 9:26pm
grafty99
Bow down
Yes Paulv8 the stalks fit quite well and are much nicer to use than the originals.
With a small bit of fabrication they fit nicely Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #582026 1st Dec 2016 9:32pm
Green Machine
Some really nice subtle mods there Grafty, and stuff I have never seen before. Great work. Those LED clock backlights look very bright! How are they at night time? 2005 Td5 | 90 Station Wagon | Tonga Green
Post #582035 1st Dec 2016 10:08pm
grafty99
Thanks green machine Bow down
My mum borrowed it the other evening and she said it was like piloting the starship enterprise! I hope she was referring to the dash and not the speed Shocked
They are quite bright but I quite like that, they are much crisper looking than with the incandescent lamps in. A dimmer is on the cards, not because they are too bright but because it's one step closer to range rover spec Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #582041 1st Dec 2016 10:23pm
grafty99
Well I've just arrived in lovely Aviemore, Scotland for a weeks holiday.
Set off from Devon at 6pm and arrived in Aviemore at 7am the next day. One fuel stop, 600 miles and 4 motorway closures later!
Had the cruise control set to 60mph the whole way (apart from the diversions and roadworks) and averaged 28 mpg.
That's with a fully loaded 750kg trailer and 3 up with luggage.
Hopefully I'll be updating the thread with pictures of the week if I remember Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #585855 17th Dec 2016 6:49pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
Yours has to be one of my favourite td5 90's!
What tyres are you running and what lowering suspension kit?
Post #585857 17th Dec 2016 7:03pm
grafty99
Thank you Defendermatt!
Tyres are Hankook Ventus 285/60R18 and the suspension is -2 inch progressive springs from IRB developments and Bilstien B6 dampers all round Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #585896 17th Dec 2016 8:49pm
Defendermatt
Cheers. I have just got some bfg ko2 265/65r18 so I will see how I get on with them. But I may be after some more road biased tyres.
How do you find the ride of the suspension. Might have to get in touch with Ian for a progressive kit Thumbs Up
Post #585933 17th Dec 2016 10:40pm
grafty99
The ride is excellent for a 90. It is almost car like, still firm but not crashy and harsh like standard.
The first portion of travel is softer than standard which makes it smoother over small imperfections in the road.
When you start pushing on in the bends it starts to work the firmer part of the spring which helps keep it feeling nicely planted - also good for load lugging and towing as it stays more level by still having the firmer part of the spring.
The axles are very well controlled in high frequency bumps and there is no secondary rebound that I've felt since they've been fitted.
On my standard setup after a long spirited drive over the moors the standard dampers would get too hot and be almost useless. On the same drive now they hold up fine and are just as good as when they're cold.
Hope that helps Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #585947 17th Dec 2016 11:11pm
Defendermatt
Thanks for the response. I was going to go with alive springs but yours sits so nice. It's also hard to find someone who has tried multiple setups to get a view of different companies. I suppose whatever I go for in the end will be better than standard.
Post #585948 17th Dec 2016 11:14pm
