Page 961 of 1383 <123 ... 960961962 ... 138113821383>
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
JWL wrote:
After giving me the odd warning signs, the odd drip down the clutch pedal, the clutch master cylinder had to be replaced. I had taken heed of the little messages and bought a new master cylinder a couple of months ago but in the true spirit of being my own mechanic I hadn't got round to fitting it Whistle
Yes it's a fairly simple job, just tedious with having to take the pedal box out meaning faffing about upside down in the footwell trying not to take out too much trim. It took a couple of hours as I wasn't on a hurry (for a change) and the neighbour and I were putting the world to rights.
It's nice when you can pick up a new part that is the same throughout the whole range from at least the 90's and 110's up to at least the end of the Td5's, should be the same for the Puma's as well
I have been getting those warning signs , it started with a small puddle under the clutch pedal, I must get round to sorting it out or give the headache to the local independent for Christmas. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #581995 1st Dec 2016 7:54pm
Huttopia
Went shooting on the normal syndicate shoot. Great day weather wise but no wind and bright sunshine don't generally work well for the birds. 107 for 675 doesn't look great but most guns were trying to be (too?) selective but couldn't back it up. It is normally a 5-1 shoot and a strong team might do 4-1. Regardless it was a brilliant day to be out.
Post #581997 1st Dec 2016 8:17pm
Grenadier
"...but no wind and bright sunshine don't generally work well for the birds....".
I'd suggest it works brilliantly for the birds, not so well for you and the syndicate!! Whistle Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #582117 2nd Dec 2016 11:09am
Chocolate
United Kingdom 2004 Defender 110 Td5 XS CSW Bonatti Grey
Had to use a second battery to start mine this morning after it failed to start yesterday.
Went for an MOT and Passed Very Happy
Now have to look at a new battery, its still on the original 12 years old, not bad.
Think the cold got to it.. 110XS CSW TD5.
Post #582134 2nd Dec 2016 11:51am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Not today (although it's the same today), and not in the defender, but the defenders temporary courtesy replacement.
The school run has never been so quiet
Laughing Rolling with laughter :lol:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #582169 2nd Dec 2016 1:37pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Went back for MOT after it failed due to a worn damper last week. Everything OK on paper, but they didn't see the leaky steering pump, and honestly I expected them to make a remark about the brake lines. At least it gives me some extra time to replace them.
Last year it sailed through MOT without any issues. I was proud since it was its first MOT since we bought the car and after I had done everything myself, including extensive maintenance, new bearings, brake discs and caliper overhaul.
Greetings,
Joris
Post #582187 2nd Dec 2016 2:56pm
John Fair
United Kingdom 2013 Defender 110 Puma 2.2 USW Santorini Black
Today I shall be finishing fitting my HD P38 long nose ATB diff 👍
Post #582333 3rd Dec 2016 7:23am
Grenadier
Curious John, but how does that DIFFer (excuse the pun) from a standard diff. What if any advantages are there? Ta Thumbs Up Monsieur Le Grenadier
Post #582337 3rd Dec 2016 7:59am
John Fair
In simple terms it's all the best engineering from various landrover diffs then the standard parts/materials are upgraded eg bigger bearings etc. The longer rover diff has better bearing spread on the pinion but has a different bolt pattern to the short nose p38 /110 rear. Ashcroft do this long nose version that is a long nose casting with p38 bolt pattern. Bigger crown and pinion gears and bolt set. Hope that help without getting over complicated. 👍
Post #582362 3rd Dec 2016 10:29am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Took the wheels off the other week, and recoated all the chassis and suspension parts, where neccessary, in preparation for winter.
Then coated the brake callipers in RAL 1018 Zinc yellow to match the Koni shock, and gave the underside a general eye over for any signs of leaks. Discovered that the rear diff breather pipe was crushed and damaged (probably during the installation of the side exit tailpipe, over a year ago). This had caused the diff to spew oil through the pinion seal. Front discs were worn out, too. On the list for the 80000 km service.
Service completed including fitting the Ashcroft shaft kit (telltale rust visible in the gearbox opening), and winter tyres fitted. The drive back from the dealership felt so smooth and quiet, which I wanted to attribute to the shaft replacement, but then remembered the soft and smooth winter tyres, which always feel luxurious, after a season of knobbly MTīs.
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #582402 3rd Dec 2016 2:10pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Heated screen wiring
Finished off fitting the wiring harness for the heated windscreen purchased during the week from Dave at VGS. As the window isn't fitted yet the loom just powers the heated mirrors I fitted last week. Quite happy with the installation, its was a very comprehensive kit including an original Landrover switch.
Post #582421 3rd Dec 2016 4:08pm
Romadog
Buzzweld painted my NAS90 V8 chassis with CIO Chassis in One. Purchased 5 aerosols last sunday at Land Rover Show. Sadly could have done with more, so will order extras. Have to say it went on really easily and whats better it dries quickly even in this weather.
Post #582435 3rd Dec 2016 4:53pm
Nothing better than a freshly painted bare chassis Cool
Post #582446 3rd Dec 2016 5:24pm
Augustus
2014 Defender 110 Puma 2.2 SW Corris Grey
Went to the supermarche the long way round.
Post #582452 3rd Dec 2016 5:48pm
Grenadier
Is that Mrs Augustus hiding her face in shame as her Defender obsessed other-half takes a photo of his pride and joy (which she knows does not mean her, really) on a supermarket run Whistle Monsieur Le Grenadier
Post #582453 3rd Dec 2016 5:57pm
