Home > Puma (Tdci) > 2 questions (bumperettes & brownchurch) |
Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
1st Jan 2011 2:06pm |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 |
Any ideas as to how I'm gonna get the BA290 bumperettes dwon here in South Africa??? Any help please.....
4th Jan 2011 12:27pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
If only you had mentioned it a week ago, my bro could have bought a set back after he was back here for Christmas. I am sure some company will post on to you. Have you thought of a different make, just that the bracket work for the BA290 doesn't look that solid. Or maybe http://www.devon4x4.com/index.php?page=sho...;Itemid=14. They will deffo post worldwide. Glyn |
4th Jan 2011 12:33pm |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 538 |
Hi all,
I've received the BA290 I've ordered but it won't fit my 90 apparently because of the mudflap brackets placed directly on the rear cross member on the 90... Did anyone successfully got these on a 90 without removing the mudflaps? Or should I cut the bumperette somehow? Click image to enlarge[/img] |
26th Jan 2011 5:26pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
This doesn't really help unless you are sending them back but the safari equip ones are like that only they have a slot for the mud flaps. You could have a cut put in them by a professional unless you know what you're doing.
26th Jan 2011 5:34pm |
Or you could cut a slot in the mud flap? Glyn |
26th Jan 2011 5:42pm |
Problem with that is if he drives offroad the chances are it could rip due to the cut. Just trying to argue for no reason since my suggestion was the difficult way, and therefore rubbish
26th Jan 2011 5:44pm |
Or.... another good idea... Buy a 110 and then you won't have the problem Glyn |
26th Jan 2011 5:46pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
I used to make my mudflaps from conveyor belt.
Multiple layers of canvas impregnated with rubber. Almost indestructable. |
26th Jan 2011 6:02pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
Rear bumperettes are very useful. Protects your rear end when a vehicle runs into the back of you. Also they protect the rear body panels if the vehicle steps off a rock.
Not all rear bumperettes are compatible with swing away wheel carriers without modification to the bumperette The cheap rear bumperettes are not necessarily compatible with swing away wheel carriers.
Whilst on first glance they may appear similar The Whitbread one The Safari Equip one Please note that the bracket design on the Safari Equip is stronger. The Safari Equip One is 6mm steel, galvanised and then powdered coated. Whitbread one? No details on web site Safari Equip do them for 110 and 2 versions for the 90 with/without slot for mudflap. HTH Brendan |
28th Jan 2011 7:53pm |
I have the SE ones
29th Jan 2011 12:15am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
@ Leeds: do you know whether the SE ones are compatible with the Mantec swingaway carrier? they look like they'd be competing for the same holes on the crossmember. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
29th Jan 2011 10:32am |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Some photos of the Bumperettes fitted to my 90.
I cut the Mudflaps to fit the angled side protector. Used 10mm thick spacers to allow fitting with the bolts used to secure the rear seat fittings - didn't want to interfere with those. However, I couldn't fit the 4th bolt - but they are very firm and I don't use them as steps so they should do their job of protecting the rear in parking shunts. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
29th Jan 2011 12:07pm |
Simple answer is that I do not know. The SE spare wheel carrier utilises the two bolts which attaches the rear tub to the rear crossmember. I do not know how the bottom bracket of the Mantec wheel carrier fits. Photo below shows the cheaper rear bumperettes fitted to red 110. Note we had to modify them as they were not compatible with the SE wheel carrier Note the score line on rear panel where we stepped off a rock in Sweden and bent the bumperette upwards. Would have done some damage to rear panel without having them fitted Also cheaper bumperettes are not galvanised so rust Click image to enlarge Black 110 with SE wheel carrier and bumperettes. Note these two items work together without modifications. These bumperettes are galvanised and when the powder coating gets knocked they don't rust Click image to enlarge HTH Alan Brendan [/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
29th Jan 2011 5:04pm |
