Home > Puma (Tdci) > 2 questions (bumperettes & brownchurch)
Page 3 of 4 <1234>
dgardel
Italy
RED-DOT wrote:
Hi, can anyone explain what bumperettes are for? Some look like they may endager the rear lights and reflectors and lower paintwork too.
RED-DOT wrote:
That is a poor excuse for bad driving... i have had LR's for 35 years and never bashed a rear crossmember yet.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #50601 1st Jan 2011 2:06pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
like it ......picture or a 1000 words!
i have a tow bar and rear bumperettes [the twin tube type] for one reason only..........car park shunts by other people and the visual deterent that if they do hit you they are likely to come off worse Twisted Evil BM52
Post #50602 1st Jan 2011 2:36pm
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Any ideas as to how I'm gonna get the BA290 bumperettes dwon here in South Africa??? Any help please.....
Post #50990 4th Jan 2011 12:27pm
Glynparry25
If only you had mentioned it a week ago, my bro could have bought a set back after he was back here for Christmas. I am sure some company will post on to you.
Have you thought of a different make, just that the bracket work for the BA290 doesn't look that solid. Or maybe http://www.devon4x4.com/index.php?page=sho...;Itemid=14. They will deffo post worldwide.
Glyn Sheep
Post #50991 4th Jan 2011 12:33pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Hi all,
I've received the BA290 I've ordered but it won't fit my 90 apparently because of the mudflap brackets placed directly on the rear cross member on the 90...
Question Did anyone successfully got these on a 90 without removing the mudflaps? Or should I cut the bumperette somehow?
[/img]
Post #55153 26th Jan 2011 5:26pm
BigMike
This doesn't really help unless you are sending them back but the safari equip ones are like that only they have a slot for the mud flaps. You could have a cut put in them by a professional unless you know what you're doing.
Post #55155 26th Jan 2011 5:34pm
Glynparry25
Or you could cut a slot in the mud flap?
Glyn
Post #55158 26th Jan 2011 5:42pm
BigMike
Problem with that is if he drives offroad the chances are it could rip due to the cut. Just trying to argue for no reason since my suggestion was the difficult way, and therefore rubbish Rolling with laughter
Post #55160 26th Jan 2011 5:44pm
Glynparry25
Rolling with laughter Rolling with laughter Or.... another good idea... Buy a 110 and then you won't have the problem Thumbs Up
Glyn Sheep
Post #55162 26th Jan 2011 5:46pm
Laurie
I used to make my mudflaps from conveyor belt.
Multiple layers of canvas impregnated with rubber. Almost indestructable.
Post #55163 26th Jan 2011 6:02pm
leeds
Rear bumperettes are very useful. Protects your rear end when a vehicle runs into the back of you. Also they protect the rear body panels if the vehicle steps off a rock.
Not all rear bumperettes are compatible with swing away wheel carriers without modification to the bumperette
The cheap rear bumperettes are not necessarily compatible with swing away wheel carriers.
Quote:
Big Mike
http://www.whitbread-offroad.co.uk/product_view.php?id=6
same as the safari equip ones, just cheaper.
Whilst on first glance they may appear similar
The Whitbread one
The Safari Equip one
Please note that the bracket design on the Safari Equip is stronger.
The Safari Equip One is 6mm steel, galvanised and then powdered coated.
Whitbread one? No details on web site
Safari Equip do them for 110 and 2 versions for the 90 with/without slot for mudflap.
HTH
Brendan
Post #55537 28th Jan 2011 7:53pm
BigMike
I have the SE ones Thumbs Up
Post #55567 29th Jan 2011 12:15am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
@ Leeds: do you know whether the SE ones are compatible with the Mantec swingaway carrier? they look like they'd be competing for the same holes on the crossmember. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #55591 29th Jan 2011 10:32am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Some photos of the Bumperettes fitted to my 90.
I cut the Mudflaps to fit the angled side protector.
Used 10mm thick spacers to allow fitting with the bolts used to secure the rear seat fittings - didn't want to interfere with those.
However, I couldn't fit the 4th bolt - but they are very firm and I don't use them as steps so they should do their job of protecting the rear in parking shunts.
Post #55600 29th Jan 2011 12:07pm
leeds
Simple answer is that I do not know.
The SE spare wheel carrier utilises the two bolts which attaches the rear tub to the rear crossmember. I do not know how the bottom bracket of the Mantec wheel carrier fits.
Photo below shows the cheaper rear bumperettes fitted to red 110.
Note we had to modify them as they were not compatible with the SE wheel carrier
Note the score line on rear panel where we stepped off a rock in Sweden and bent the bumperette upwards. Would have done some damage to rear panel without having them fitted
Also cheaper bumperettes are not galvanised so rust
Black 110 with SE wheel carrier and bumperettes. Note these two items work together without modifications. These bumperettes are galvanised and when the powder coating gets knocked they don't rust
HTH Alan
Brendan
[/img]
Post #55621 29th Jan 2011 5:04pm
Page 3 of 4 <1234>
